kwickr33:
Yes we have internal wastegate kit for your turbo. will cost $200 with bracket and high pressure actautor.
Gtscott:
We buy Garrett bearings, seals plus certain bearing housings and we do our own assembly.
Hey Stao, I'm looking to upgrade to a TR43 G1 with a .63AR in the next month or so.
What sort of wastegate actuator options do I have?
I know you don't typically make them with anything less than like 10psi for skylines etc.
but for my X-trail, i need a low boost setup to work off before i raise the boost with a controller.
If I was to order one, can you include a 5psi actuator?
Thanks!
Little update:
I've managed to build a "HKS2530" in a larger .86 T2x turbine housing with OEM RB25det bolton pattern for RB25det engines. Should produce identical amount of power with similar response and better torque for the Rb25s.
Photos:
any chance you have a garret gt30 ex hausing with rb style flange on there do you?internally gated if possible
Yes we can do that.
The GTRS would be a smaller trimed 2871R. I'm also building one with larger comp trim. My engine is almost finished. I will put that on and see what happens.
im just looking to buy a garrett gt30 rear exhaust housing,i believe the genuine garrett option is best suited to my turbo,gt30 71r non cropped turbine
The genuine Garrett GT30 internally gated turbine housing I have a listing for $650AUD including GST brand new in .82 A/R.
Can i ask, which turbo and housing is best for r33.
Thing is: i dont wanna upgrade injectors, PFC, z32 etc.
I just want to run MINES ECU, Bosch fuel pump, exhaust and cooler on 14 psi, (stock injectors and z32). So around 225kw is probably aim, but would have to be responsive.
Stao how are you mate...
im after a turbo for my car gt 3540 - 2530 but i want the power of the 3540 with more response... is there a half way kinda turbo out there td06? or something i was told.... now im after 230 awkw on the gts4 but im gona want more later on..... ive spoken to you late last year.. about this but theres so many to choose from.. whats gona be best for my rb20 ?
regards George
That is the easiest question ever to answer.... the factory turbo, as your Mines ecu is tuned only for the std turbo and std afm. It will run with the z32 but the map scaling will be up the shit.
If you do swap the turbo it will just be a matter of time before you have a nice mess on your hands.
regards George
A gt3540 will make 400rwkw a 2530 will make 230rwkw..... big difference.
Hi George you can use our ATR43G3 in .63 turbine. It can get you about 240~60rwkws internally gated on RB20det with full boost around 4500RPM or some thing like this:
This is a ATR43G3 .63 turbo with built in External gate that is designed to bolton to stock RB20det's manifold, dump, and all lines.
Above was built for a Rb20det customer.
Also like to add all of our HPVA external wastegate are equipped with a Genuine Tail 38mm external gate Diaphragm:
Stao will the ATR43G3 in .63 turbine do 230-260 awkw comfortably ? i dont wana be driving around on 21 pound lol
also if i can get 260 kw i think thats plenty coming from an rb20... might stick to the atr43g3 with .63 also price it with internal gate please ta!
Edited by v8tzr
Yes you need to run 20psi to get about 260rwkws with stock rb20det. This engines need abit of boost to make power.
For comfortably I would say around 245rwkws. with about 18psi of boost.
Price? on one of these? will be purchasing within the month..
Price on those is $1450 including braided oil feeding line and GST. will cost $150 more If you want external gate built it, which is highly recommended for high boost applications.
This also includes 12 month warranty for all high performance applications. Means your warranty does not void if you run 24psi every day like I do and drift it 24/7.
hey stao,
Im running the older version of your turbo turbo the tr43i .63 on a r33 on 17.5 psi and getting fullboost at about 4500 and 260kw, wondering how much difference your new atr43 g3 would run? would it be less laggier?
    • I've watched some vids and the technique seems to be to butt the sheets up to one another and use MIG to spot weld and slowly fill in the spots until its eventually all sealed. No runs as you would normally do, as there's too much heat generated that way. Yeah my stick welds are terrible these days because its been so long since i've done any of it. I expect to be spending many hours practicing
    • I have personally seen a Tomei USA RB26 cam that didn't even fit the head. Kind of nuts to me that it was even possible for that to happen but such is life.  There's two UP Garages in the US. One is a US branch of the Japanese company which sells things they brought over at tremendous markup. The other is University Place Garage/Fairlady Motors which is a shop best known for putting VCAM in RBs and trying to convince people to stop putting in 800hp of turbo on a 2.5L motor.
    • Gasless MIG is not exactly suited to what I would call "delicate" or "attractive" welding. So I would rule it out for sheet metal rust repair type stuff, unless you're only doing it in hidden places. I'm thinking about getting myself a gasless MIG for "hack together" type work. Noting that my welding experience is very very low, and quite a long time ago. So I'm also looking for "simple", but I'm not expecting "excellent". I'm not even sure that proper MIG is the best for sheet metal work. I get the feeling that the degree of control and the minimisation of heat input that you get from TIG is probably what you really want. And then you have to get good at doing it before the welds won't look like a monkey flinging a handful of shit anyway. You're probably SOL for an easy and cheap way to get from where you are to where you want to be. Much like myself.
    • Any recommendations for what would be the easiest welding type to start on, for sheet metal rust repairs and maybe some exhaust piping too? Seems like MIG is the most common. Would gasless MIG be ok to learn on and do some simple jobs? I have a stick welder which has a Lift TIG setting, but i'm more interested in getting whatever's easiest to do, and most suitable, rather than using what i have.
    • Is the UP Garage in the US of Ayyeee even the real UP Garage?
