If only your mother knew of the word! :P
Most of us here are more concerned with kilowasps and efficiency than checking out our gelled hair in the reflection of a pipe...but each to theirs I guess!
good one. im gonna use that next time!
Scottys work fabrication is some of the best I've seen, I'de rather a strong weld that will hold up under extreme circumstances, than something thats probably been made of the same quality as tin foil.
He's probably the only fabricator I'de trust working on my car, or anyone else's car locally
Quick update. I have boosted my SS2 to 15psi and it goes awesome considering its untuned. Knock didn't go past 18 (had a previous tune that accommodated the boost. And clutches kicks are a dream with the twin plate. Getting tuned on 18-20psi on the 15th. If I get time I'll post up the results of that. In all honesty it is a bit laggy for me but I'm very picky. Just got to learn how to accommodate for it when I drive.
Surely tune will help with this, seems premature to evaluate.
Lol. How would you know what my idea of laggy is? I have doubled the rear wheel and rear housing size, so I think it isn't premature to evaluate this. Even a good tune won't make it not laggy "in my eyes". But each to their own I guess. Some people don't think a g3 is laggy and some people (me) thinks a ss2 is. Its a fantastic Turbo and so dynamic but as I said I have to get used to it.
Looking at the ss2 dyno and having driven similar turbod cars I would say it is laggy by most peoples definition, laggy for it is though? no
Edited by Rolls
Lol indeed.
Well it's true laggy is subjective, but he's right, the tune will help with spooling and power delivery. Will also improve the off boost fuel/timing so that the lag itself isn't that bad.
Yeh but it doesn't say Greddy and you can't see yourself in the polished reflection.
I make practical intakes that work, not fap toys. lol.
Have to agree there!! Have seen a lot of Scott's work and seen his piping hold 550+ rwkw, practical is just the start of it! It might not have a badge, but probably flows better and has better value for money than "badges" out there. Some of his custom designs are awesome, even trying to get him to do some improvements on some fabrication that has been done to my car.
Thanks Shadz, drop in sometime I can definitely help you out. (If you're keen to drive an hour each way for some work to be done mate.) :)
On topic, I have an M35 turbo coming down to you for one of those new 'responsive' highflows on the previous page Stao. I will call when it's out. Thanks for sending him my way buddy, I will look after him.
I forgot to mention in the last run before the head gasket cracked. That SS2 has a customized housing, it is slightly more responsive then the one before that model. SCR48 has that housing. Adam come for a test drive in the newer housing have a feel of differences once I get the car back on the road.
Latest configuration
The one earlier:
Some updates:
The manifold finally came back from Brae auto fab:
and it will be running on a 50mm external gate:
This is still a bolton manifold that holds a turbocharger in stock position. How ever I'm going to wait for the later and cheaper manifold prototype that said to be complete on Monday.
The head gasket also shown up. how ever it isn't 1.1mm as what the seller claim to be. 0.051 of an inch calculates to be 1.3mm.
any one had experiences with 1.3mm head gaskets? or I'm just going to install another stock gasket back in. hopefully it will be back on the road towards the end of next week.
I'm keen to see what the SS2 would do at its full potential, on that setup, then follow it by an updated version of the SS3 now has a different wheel curvature, which I'm hopping to hit some where close to the 400rwkws mark with similar response as the SS2.
By the way SS1PU is now available in a SR20det bolton form. A trail with customers stock S13 SR20det have reported a final figure of 270rwkws @ 17psi using 260 duration cams on pump 98 responsively. I will pickup and post the dyno read out coming week.
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
