Its very unfortunate that Brae have finally gaven up on the simple log manifold design as cyc No. 4 can not be bent that far to suit stock position. I will speak to few other welders and see what other possibilities are. But for the time been I will be assembling my car with what I've got and have that back doing its jobs soon as possible.
surely you could use whoever makes your rear housings and get them to make a modified version of the cast iron hks manifold
(make it so that it bolts on easily)
If the goal is stock location the HKS low mount isn't going to be the answer.
stock location won't be needed if its gonna come as a whole kit (dump included too)
Looks like I might have to go high mount to keep the costs down. apparently the side mount takes too much efforts to complete. There's one more welder who'm happy to give it a shot, we see how it goes.
Is the manifold you posted on the last page a more expensive design or mounts the Turbo in a different location?
That is a $1100 manifold, the log manifold will have 123 goes into one plus and 345 in another. How ever there isn't enough room to merge 345 as the steam pipe bends are too big. If you go back and have a look at how my manifold is constructed, there are lots of efforts and man hours spent.
Yes by die-grinding stock manifold would help on picking up 17kws, pumps it to 297rwkws internally gated.
Do you have the ability to open up stock manifolds? If so, why not try and source say five stock manifolds, prep them and then sell them as part of a kit on an exchange basis? Charge people an extra $100 that you'll refund once they send in their stock manifold.
Might be easier and a shed load cheaper than trying to get your own steam pipe manifold sorted?
Just a thought.
^^^ good idea. I pulled a tonne out of mine. Surprising how poorly the ports matched the head. Plus the collector flange is much smaller than the gasket.
Whoever purchased a ss2 running ext gate is in for a treat.
Just got my car tuned at chequered tuning
Initially got 295 but wanted to be safe so turned back the timing.
So final =
276rwkw
18psi tapering to 16psi
Full boost at 3800
There is an abundance of wheel spin and really quick acceleration . Very happy.
So final =
276rwkw
Full boost at 3800
cool, do you think its laggy now?, Stao ran a bit more boost didn't he..21psi tapering to..? be good to see the dyno
sheet
Edited by jet_r31
Yes, In my opinion it is still laggy. But that is greatly outweighed by the power it produces and the smile it puts on my face on boost. Mind you it has performed just as well if not better than Stao has described it would so the turbo for what it is is great.
Mods are as follows
Z32
3" exhaust, no cat, 1 muffler (home-made)
600x400 bar and plate cooler with return flow piping, assuming its home-brand as i only paid $50.
Tial 44mm gate (17.64PSI)
SS2 0.82 type b
52mm Radiator
bcpr7es copper plugs
DW 740cc Injectors accompanied by a Bosch 044 (intank)
EVERYTHING else is standard
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
