Is it just the scale being used on plots or does the torque fall over a little at the top end?
That do respond to boost drop, where torque tapper represent where the boost at its lowest point. Per graph below, 6500RPMs and later the boost level is at its lowest point of 18psi. So it matches where it initially made 18psi at 3600RPMs, resulting a bow shape power and torque curve. There are improvements in it using an external gate holds boost straight.
This is the boost curve from run earlier using latest SS2 turbine housing vs Adams using earlier turbine housing on pump 98 fuel:
and notice how power and torque respond to boost level:
I'm not too worried about the torque drop, pretty much all turbos in that HP range does, and responding to a combination of the turbo and engine setup as well as the fuel instead of the behavior of the turbocharger alone. Generally larger turbos with better flow waste gating and manifold plus exhaust system hold torque longer. Instead of the shape I'm more interested in the physical No.s it produces in mid range, in many cases you might find the end torque is same while the bowed shape curve had much more torque through mid range.
thanks for posting this, what is the price in external gate T3? .63 AR
That is in a T2x .64 FNT turbine housing. Its a bolton turbo for stock SR20det's manifold dump and every thing else (S13 SR20det needed oil feeding line)
My car is actually set up for T3 high mount now, do you have a housing for this or will you need to make one?
Yes I can make that into a T3x flange still in the .64 turbine geometry. Is that for external gating?
Hey stao how did u go with the exhaust manifolds ? Will they be for sale ti public?
The one that I've got didn't quite work as the screamer had no room to go any where, Abe's making a budget high mount at moment, he said he will have it done by the end of this week.
I'm also doing some fabrication work on stock manifold at this stage, that involves milling the top of the manifold log, then weld it back with larger diameter steam pipes, as well as the connector pipe for external gate. Its going to be an exercise that cost around the $500 mark, if works well, then its much cheaper then making a whole manifold while holding every thing in stock position.
Yep that's an external gate.
I would want it to be a simple housing with a v band out. Not the old 5 bolt housings with a plate adapter, is that possible?
You mean some thing like:
Ah, thats actually the type I am trying to avoid haha. But it does not look too bad to be honest.
Can you please PM me a price and the wheel dimensions? In and Ex of both comp and turbine if thats OK. I just want to make an educated decision.
Thanks,
Here are some updated photos for the new high mount manifold.
I should have it on Monday for some details description. Pricing wise, this is $650 with any turbocharger or high flow service purchased Or $800 by it self. Add $200 additional we can also make a 3.5 / 4 inchs (not sure if 4 inches fit yet) front pipe. Discount applies to all of our customers whom has previously purchased and currently using our turbochargers or high flow services.
Externally gated version of any of the ATR43 series are $275 cheaper then the common bolton versions. So price for the whole kit would be:
ATR43 Gx series: $900 + $650 + $200 front pipe = $1750 (exc external gate)
Or
ATR43 SS series: $1100 + $650 + $200 front pipe = $1950 (exc external gate)
We can supply 50mm external gates for $200 additional. or you are welcome to bring in an external gate for an adapter pipe to be made onto the manifold.
That's a nice manifold stao, and a good deal for customers too!
interesting to see what turbo is in that first photo though lol.. Is that a billet version from you? I would love to see the results.
Whens your modified stock manifold going to be ready stao?
Yes it is working in progress at this stage. its not as easy as I originally thought.
Lol..you did some billet td06 20G's all tidied up at a good price Stao..is there any plans to sell any td06 25g's with a billet wheel
tidied up aswell?
cheers
darren
The Billet TD06 has been sold to a SR20det customer. I don't have drawings for 25G comp wheels at this stage. So only 20G billet version in 8 or 10 cm. they are $750 each for any one whom's interested. Yes can be tight up to the manifold deal.
Its all back together now using Brae's manifold. The best I can get his price down to with this version is $1250 with the wastegate screamer.
Now with Heat shield on:
ACL make the heatshield mate, buy it in sheets, i like what you have done with it stao, exactly what i planned to
do..lol
I thought you would get a billet compressor already made Stao like this:
http://www.ebay.com....=item43b2f69a7d
I didn't realise you would make one, or made one for the 20G
cheers
darren
Edited by jet_r31
The firm makes the 20Gs for us in Taiwan doesn't have 25G comp wheels or housings unless I can send them a drawing or a sample with a big order at current stage. I'm also not currently looking to stock heaps of those, but might change in near future.
The SS3 prototype made 387rwkws on 23 psi of boost on E85. In fear of snapping factory con-rods this run was done on a quick 9sec ramp timing that makes it laggy on paper. This is with the Brae manifold with external gate per photo graph on above post. More work will be applied to this prototype.
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
