lol ramps a little steep, 150-330kw in 700rpm
He explained why that is. It's a 9 second ramp as he is concerned about the stock internals holding up to such huge power.
It would make for an interesting drive, however :)
Wouldn't a shorter ramp actually make it look laggier on paper since the dunno allows the rpm to climb faster?
yes Trent wasn't very confident with stock con-rods when we got to around 375rwkws, faster ramp puts less load on to the engine, and generally result that sort of power curve. I was hopping for 400rwkws at the time ;) .
On road its obviously not as responsive as the SS1PU or the SS2, but pulls crazy after 4G on full throttle. I'm putting the SS2 back on for the final tune based on external gated setup and e85.
My ss2 is booked in at allstar garage in 3 weeks. Running it in between now and then once brake pads arrive. Hopefully have a drive this weekend
The turbine housing used on that run is a .82 type B rear. I believe type A would have produced more power. How ever this is the first prototype that made into this sort of power range, so there are many areas that could be twicked for even better result.
I think G3 will max out around the 370rwkws mark based on the same setup. I will do a test based on it in the next few weeks. I've also got few idea on high flowing factory R33 and R34 turbos that I like to trail.
Further evaluation on the SS2. it made 337rwkws on e85 externally gated at 18psi peek just touching 20psi. I've also trailed it based on internal gate running boost controller and straight off the actuator.
The solid red and green are from internal gate, Green is internal wastegate pressure:
Boost curve for all runs.
My ss2 internal gate turbo is ready to be picked up tomorrow.
Going to installed on a healthy rb25neo, ID 1000 injectors, z32afm, Hybrid turnflow intercooler with one of Scotty's metal intakes.
Will be tuned by Trent at Chequered tunning.
Will post up results when everything installed. Probably sometime in the next month
Ooo, nice one Tony. e85 I hope?
Nah not e85. It's my daily and I do alot of road trips on weekends.
So don't like the idea carrying jerry cans in the boot everytime I need to travel.
But yeah ID 1000 injectors just in case I ever change my mind in the future :P
It would be interesting to see what your G3 style hi-flow(PU?) did on a stock exhaust manifold and E85,
eg ..most power for a full stocky look
cheers
darren
hypergear can machine the stock rb t3 inlet cover to match up and bolt onto the ss series of turbos which means stock looking turbo
Edited by Dan_J
Yes can run stock comp housings on those.
Some updates with factory exhaust manifold fabrications. Well yes it is a not an welly engineered part. The port don't match up with the head as we already known, they had huge lumps in side the collectors, looks like they were trying to seal the bolt holes when the bolts aren't fastened. The lump took almost 40% of the total volume area that merged cyc 4 5 6. That really explains why its always the last few cycs that blows up when ever is an engine failure.
This is what they are like now, with the top half milled, lumps cleared out, and I'm going to weld steam pipe over the top to increase the overall volume of the manifold log.
Very nice, photos really help show the progress your making :)
Will these be done on an exchange basis or will you have stock?
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
