I'm talking about a VQ not an RB.
Why would the engine matter? The turbo will pump X amount of air, and if there are no restrictions any engine should run around 300 on e85 with an SS1PU, maxing out the compressor.
Isn't displacement a restriction? I would have thought at a given RPM the turbo can pump more air through a 2.5 than a 2.0.
Yes it is a restriction, hence why you need more boost to make the same power on a smaller motor, same as smaller cams need more boost etc etc. Though technically he accounted for that by saying "no restrictions" which basically takes the engine out of the equation and assumes a magic black box that has no friction/pumping losses etc lol.
Edited by Rolls
I mean stick,mig or tig?
I'ma take a stab and say not any of those three.
Brazing is the likely best and easiest way to weld steam pipe to cast.
If not, then maybe Mig. I doubt Tig or arc would get a look in.
Stao?
Edited by Cowboy1600
Tig would easily do it, many people dont even bother pre heating the cast
Just been doing some Googling on welding cast and it seems pretty much every method is possible, which I was unaware of, but tig and mig would appear to be the least popular for something like an exhaust manifold as many heat cycles causes it to become impregnated with carbon which makes it brittle.
I found this site - http://www.weldingtipsandtricks.com/ there's some great info there for anyone who's interested. I love welding although don't get to do much these days.
Did you calculate the extra volume?
If not, it'd be great to do so. Block off the turbo outlet and fill that sucker with water. Then compare it with a stock one.
Can't wait to see results.
Also, would running a die-grinder around the ports to open them a fraction and smooth them out be beneficial?
I know port shape and smoothness on intakes are very very delicate, but I don't think the same applies to the to side. In fact smooth ports might speed up gas flow which means faster spool. At least that's my uninformed theory :)
Might have been worth running the die grinder over the whole inside while the back was off. Maybe give that a go next time.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
