Smoothness of the wall inside an exhaust manifold like the RB one is going to have a very very small effect on the flow/pressure relationship, compared to the terrible, terrible aerodynamics of the bends and joins in the log itself. It is actually possible to get better flow with a rougher surface, especially on the inside of the bends, because a thicker boundary layer is less likely to seperate off the wall (or at least, it will not seperate until a higher velocity is reached). Keeping the flow attached almost always wins.
The outermost ports on the RB manifold are poorly aligned with the head's ports, and so one of the things that Stao did in that mod was to port the manifold to improve the match (and that is a long standing known improvement anyway). As to "port matching"......it is actually better if the manifold flange openings are larger than the exhaust ports on the head - by 1mm or so all around) to try to create what is known as an anti-reversion step. The idea being that the change in section does not cause a bad upset to flow when the gas is flowing out of the port into the manifold, but the step creates a place where a pressure change needs to occur to force return flow (such as when the exhaust valve is still open but there's a pressure pulse elsewhere in the manifold that drives reversion gas back in through the exhaust valve). The pressure change is sufficient to cause the pressure wave to bounce back (ie, it's the "end" of the runner, even though it's not actually the end) and reduces the amount of exhaust gas reversion into the closing valve. It works. It's probably less useful on a turbo engine where we simply have high exhaust manifold pressure anyway, and arguably less useful on a crude log than on a decent long tube manifold.... but you'd still do it if you could (and it didn't compromise any other aspect of the design) on the basis that any little help is good help.
Have my g2.5 on the car given it a bit of a drive. Seems very good but can't get up it properly till tuned yet :(.
I highly recommend Hypergear to anyone interested in upgrading their turbo. My turbo was an old used one I got off another member which was stuffed. Sent it down to Stao and he replaced everything (except housings) for around $400 and he also updated the rear housing to 0.82B for no extra cost on top.
I know I wasn't the easiest customer to deal with but he was always professional and helpful so a big thumbs up from me looking forward to a safe 270rwkw
Thanks for the feedback. Looking forward to see your dyno results.
Further updates with the fabricated factory exhaust manifold:
It took me 4 hours to remove brae's manifold. I believe there is a need for small alterations in design which allow tools reaching and turning manifold to head studs in a compact area. Installing the stock manifold was a piece of cake.
It still runs the SS2, I will take it back to Trent for some dyno runs on Monday. Assume no timing reduction while power and torque curves mirrors, then that would possibly confirm my $500 alteration work perform as good as some of the $1000+ hand made items.
There is a very noticeable gain in response using with this manifold. I'm very sure it has lesser volume compare to previous, plus shorter runners would've also helped. hopefully peek outputs stays the same.
The factory manifold is a twin plus log manifold.I prefer keeping it that way, refer to previous photo, note the curvature in bends of both manifold logs. if that has been milled then exhaust gas will run into a flat end, its also the reason that I didn't mill into the merging point. External gate in this case can be attached to the turbine housing since the manifold is no longer restrictive.
The Tube ID is 45mm
Also an prototype actuator was made. it has adjustable rod that allows pre-loading, but also allow adjustments to spring load pressure. Similar to certain external wastegates that allows spring load adjustments. By using this prototype, I'm hopping to hold steady boost levels in upper rpms range, similar to an external waste gate result.
I've finally got some results sent in from our version of billet TD06SL2 off a S13 none VCT SR20det. It made 282rwkws on 18psi with E85 , it should just touch 300rwkws at full potential. This turbo is now available for $800 brand new for any one's interested. Far as I know the car has 264 cams with every thing else standard. And that is on a high mount T3 manifold externally gated.
Think so. You need to run them externally gated to get the numbers.
Also some results about aftermarket v Stock manifolds.
Per last page referring to the modified stock exhaust manifold. I've done a back to back test today V Brae's exhaust manifold.
It is actually more responsive as I've felt, however also down on power. Pink is modified stock exhaust manifold, while the other two are from using Brae's manifold. free flow manifold produced more on lesser boost, proper manifold is very necessary for power making.
You need to get hold of a stock standard manifold and compare it to that because that's what it's going to be replacing. I can't see it being attractive to someone who already has an aftermarket mani. Myself, on the other hand, would consider yours if the price is good and it compares favorably to stock.
I think what he meant was get a proper hand made manifold with a proper external gate system for better power.
yeah but someone with an aftermarket manifold already won't buy one of these
someone with a stock mani would, so it would be handy to know what sort of difference vs stock there would be
Eggzacery.
This manifold is targeted at people currently running stock manifolds.
The only way Stao is going to confidently say that it's a worthy ~$500 upgrade is by comparing it back to back with a stock manifold and showing the improvement, assuming there is one.
Well that level of gain Its not worth the $500, a cheap china manifold would've gained better result. I won't be providing that service.
mean while we also did a power and boost comparison using the current SS2 against the T67, both on E85 and ext gate (I need harder springs in mine). this is obviously not official just some thing interesting to look at.
Red is from SS2 the rest are from T67.
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
    • Potentially some interesting data for some of you here; Hank Iroz from Iroz Motorsport testing a new Xona Rotor 5964S on a Audi RS3 2.5L DAZA motor. https://facebook.com/share/p/14EU18MyDqZ/ Cliff Notes: Turbo has the new Xona XRE compressor aero with an X4C compressor cover, reportedly 0.64 rear housing. 900whp (670kw) @ 37psi, 170k shaft speed, motor is making 2bar (29psi) boost by roughly 3800rpm, 500lbft (670nm) torque by 3500rpm. They overlaid a stock RS3 on USA 91 fuel (red), and a "Stage 2" RS3 on E85 (yellow), and this 5964S (blue) - the 5964S isn't losing any ground to either. Apparently out-flowing their prior tests with a Xona 8264S (green), and this 5964S (white) also has a smaller A/R than that did.
