If i say it pulled hard at 5 psi would you calm down :P ??
That was my test drive around the block to see if i could put it down to the tuners lol.
ECU has a tune for 500cc injectors in it already, so its not driving on stock settings
Edited by jay-rod
Sorry I don't think you can run 5psi on it. if it is then check actuator preloading.
Lol still, don't go boosting around with a turbo that blows more air at 5psi than the stock one would at 15. It's just not tuned for it, and boost pressure has little to do with the state of tune in this case.
once its tuned we will be more than happy to hear about teh awesums.
Im not dun worry :)
I got my 1989 Mx6 Turbo to do that with :P
FYI my skyline has had a slipping clutch since i bought it ( put new one in) ....so its a completely different drive even without turbo.
Also it did take a little "Convincing" to get the water lines to bolt up again.
Had to remove them and bend them to the correct angle, as the new turbo has higher water outlet than the stock
Edited by jay-rod
yeah, they are a custom made item afterall. a little bend on the lines still well within the bolt on category, not a hard task when how little custom work is needed.
Why cringe at valve guides? Because they are custom or doesn't trust they were done properly?
He said most places measure the guides and think they are too loose and need doing, then they make the custom ones tighter. But if you actually look at the Nissan specs, their valve guides are much much looser compared to most other heads. Not to say that what Headtorque or any other head shop does is wrong, he just said it can cause complications.
When do you get it back martin?
Well I had knee surgery today, so I'm actually writing this from my hospital bed lol. But my tuner just texted me:
"Car went OK. Didnt ooze hp unfortunately. It doesn't like boost at all. It appears there is a restriction at around 340 or 350 hp. After that it doesn't make good hp. 20 psi is hardly any more powerful than 16 or 17 psi which indicates a flow restriction or bad intercooler that has pressure restriction. It went about 350 at 18 psi but went almost the same hp at 16 psi. Needs pipework fixed up. Blew 2 pipes off. Base timing was 10 degrees out. Very hard work."
I'm happy with that for now! Considering the run I've had with this fkn thing so far, I'm impressed it even made it off the dyno :glare: I'll upload charts when I can. I now intend to hammer the fkn thing at Powercruise, drive it for a bit, then I'll look into sorting out whatever is holding it back.
Re-dynoed today.
VCT is fine- about 60hp difference disconnected
Afr is 11.5 from 3500-redline
Apparently has heaps of timing(i havent checked numbers yet)also so it's very safe. Pulling 2 degrees from 3500+ helped spool a little and made 15hp more with 1 psi less boost.
Will change exhaust and double check cam timing when I'm back from Japan then back to Perth for more tuning.
Stao I see your updated SS2 turbo on facebook lol
Looks good!
Hopefully you sort out your issues Trev. Mine should be installed and on the rolla's in about a month
Had the car tuned again today and we had some pretty good out comes. All results today are still based on the ported factory exhaust manifold.
First of all the twin actautor setup tested and the result went exactly as expected. the amount of boost drop was halved. Graph below shown twin actuator setup from today in orange while blue was the single setup from last week:
This was the single actuator setup from last week with figures:
As we can see boost drop with twin actuator setup is 1.2psi, while boost drop from a single is 2.6psi.
As for turbine housing concern I've used a .82 type B rear working with the SS2's CHRA. the result was 3 degrees of extra timing up top, with exactly 21kws of gain. Orange is from today, while blue is a custom profiled .63 rear housing from last week. This combination is probably best SS2 option working with stock exhaust manifold.
Teaser video of my car running again:
Mate was driving and was too nervous to drive it hard, so when I can drive again I'll get some better footage.
    • Have you tried another indicator stalk? Sometimes these go bad and cause issues.
    • They're so beautiful 馃槏
    • Early last week, I became concerned that the car was feeling....slow. Most of my driving is commuting to/from work and there are few opportunities to get up it and convincingly make boost/power. It drives in vacuum almost all the time. But when you do occasionally get an opportunity, and.... it takes a little longer to start making power, and then there's not as much as you'd expect, and then you run out of road anyway and have to bottle out - it can be hard to be convinced that there's something wrong. But by the end of the week I was pretty convinced. Made an effort to get a decent test run. Took bloody forever to come up on boost and when it did it would only make about 50 kPa of pressure. There was no black smoke, no noise of a boost or exhaust leak, no evidence anywhere of an intercooler hose clamp being sloppy enough to let air escape. So.... not that sort of problem. Brainstorming led to thinking that the boost controller's solenoid might have failed in some way. No active boost control would just give wastegate pressure, which I was more or less getting, and the laggy behaviour could just be "normal" shitty boost response from an uncontrolled highflow. But a little extra 3rd party brainstorming led to the thought that the actuator circlip might have jumped off leaving me with a bluetooth wastegate. So, on Friday, off comes the stock heatshield (which is an annoying enough job on its own) to reveal - yup. WG is wide open. And.... it won't come back. It is jammed in the dump. Put the rod back on with a new circlip and tried driving it to get it hot in the hope that the capture was from thermal effects having been blown into the dump when hot and since cooled. Nope. Won't move, even with screwdriver mediated force when hot. Ran out of time to play. Came back to it yesterday. Unbolted the dump. Was lying under it with the dump jammed up against my guts undoing the bottom 2 bolts. Got them most of the way out and gave the dump a serious heave. It didn't noticeably move, but there was a satisfying "plink" noise from up to. Shuffle out and sure enough, gate is now closed. Nevermind that there was still the better part of an hour after that required to put it all back together. f**ken cars.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
