Teaser video of my car running again:
Mate was driving and was too nervous to drive it hard, so when I can drive again I'll get some better footage.
Can't watch the video brah
It made barely any difference Aaron, the dyno result was from two different AR rear housings if I read it right.
Stao, were they 20psi actuators?
We are talking about 1.2psi gain, not a mojor but there is a difference, notice the shape of the curve too. The 20psi actuator still had 3psi drop. this sheet was taken when using the same turbine housing
compare to:
The SS1PU probably had the most boost drop internally gated, this actuator setup should work well with that.
Do you bore out the wastegate hole Stao?
Maybe you could look at the EFR turbos and borrow some ideas from them to come up with a better rear housing design?
The SS1PU due to the higher pressure in the exhaust manifold, too much pressure here would cause heat issues though, you need an exhaust temp sensor in the manifold imo Stao.
Have you incorperated the longer actuator arm for more leverage also?
Ahh crap, I missed that the bottom graph was the two different rears.
Please refer to post 6125. They are identical turbochargers, both with .82 type B rear housings just different actuator setup.
Talk about great service!
I ordered my turbo on Monday, it was built and is already in the post. Stao has still been answering my queries and testing products in between, now that's what I call great service :)
Different arm to mine but looks to be similar length so should have same leverage
Stao mine has the longer arm and I lose 2psi up top. Is it worth loosening the screws and extending it out to the edge of have you tried that and made little difference?
Edited by t_revz
Speaking of restrictions...both my cams look a couple degrees retarded. Might have to grab an adjustable gear for exhaust cam. Obviously need to put a dial gauge on and check for sure but if I see cheap cam gears in Japan next week ill be all over em
    • Thank you 🙏 I'm patient, which is good, considering the limited budget (for now) more so trying to understand where to begin the journey and you and the others have been good with that, appreciate everyone for their input 🫡
    • $5-10k isn't much for reliability if your looking at more power for a RB Me, with that much money currently on hand,  I would only look at things to suit future mods, as stated, a fuel pump and ecu would be my first point of call, as well as getting the injectors cleaned and tested, maybe even replace all the coolant hoses After a little time with the tuner, they should be able to tell you how your car is running in relation to things like your ignition, cooling, and other stuff that will be picked up when it has had a few runs up on the dyno and some logs to look at Basically, get everything sorted for reliability before you start leaning on a 30 year old engine Good luck with the one and only true Godzilla, enjoy Note: for your birthday presents, ask your family and friends for lottery tickets, a 32 GTR can cost "all of the money" to make reliable power
    • Strictly street. Just wanting a bit more power 🫡 Have baby seat in the back too 🤣
    • Yeah ok, it'll be expensive. But it is what it is.  How do you plan to use the car? Any track work?
    • I do have their “Nissanie Motorsports Co.” vin plates, but I am curious if anyone would have more info on them. Like how many cars they’ve imported and whatnot
