Stao why don't you try make the TD06 work with you .82 type B housing?
with a little machine work you could be adding a whole new product to the market.
  On 02/10/2012 at 11:46 AM, hypergear said:
The SS1PU is not a GTRs.
2ndly if you are comparing td06 to a GTRs its never been compared on fair grounds. Install your td06 internally gated in a stock rb20det manifold plus all the EGR and road legal crap you would normally expected to run on a stock setup, The TD06 would not perform any where near a GTRs or a SS1PU.
All supporting mods counts, The turbocharger does not take all the credits.
I hear what you are saying. SO many people carry on that the std manifold is good for 300-350rwkws etc, I have long been an advocate for binning exhaust manifold asap...but others are happy to use it and hold back the performance gains available to them...combined with the fact for the same price of the HKS GTRS you can buy a complete TD06 setup. So based on dollars spent it is a fair comparison.
Anyway , interesting to see more billet results
So I received my JJR 3inch dump today.
It appears that the inlet area of the exhaust is smaller than the outlet area of the turbo. in some places about 0.5cm in width and length about 1cm. I'll try and machine as much as I can but doesnt appear to be that much room.
Thoughts? Will it be much of a restriction?
Heres a pic, not the best
It needs a little die grinding by the looks of it, as does the adapter Stao machines up imo.
Can't the machinist at least round the corners a little Stao? Is it a CNC mill?
All the corners in the .82 B rear housing has been rounded off, The flange area can't be any bigger, its been traced through the gasket.
For the Billet TDxx series to work probably there is a need for a proper exhaust manifold, external gate, and a front pipe. I'll get them sorted very soon.
Stao why don't you look into getting a spacer plate made which accommodates your external gate?
that way you can offer the turbos in external format and the user just needs to make a dump pipe, which you can supply a v band ring and clamp for.
Yeah will def be fixing up the dump pipe
Want everything perfect before I fit it all up and dyno it, rather than going to the dyno and finding out all these restrictions
  On 04/10/2012 at 10:45 PM, GTScotT said:
Stao why don't you look into getting a spacer plate made which accommodates your external gate? that way you can offer the turbos in external format and the user just needs to make a dump pipe, which you can supply a v band ring and clamp for.
I should imagine that a spacer between the manifold and the turbo that is big enough to have an outlet for the wastegate will start causing problems with pushing the turbo outward/upward/downward enough to make it start hitting other stuff. Certainly on the factory turbo manifold you'll hit the strut tower after only a smallish push outward.
Ive seen one of those ebay spacers with the 2 bolt flange plate used to mount a precision turbo on a skyline before. It certainly can be done, and if Stao makes the spacer himself Im sure he can also make sure it fits well.
Then again he can just supply housings with a gate port
Dimensionally (in/ex) its the same size as the existing 20g, its blade design that changes. Front cover is the trust style .60
if changes have been made to either inducer or exducer I'm sure stao will correct
  On 21/09/2012 at 2:50 PM, hypergear said:
Updates:
I'm getting some steam pipe bolton manifold and high mount manifold made overseas as I'm typing. I should have a prototype received by mid next week for trailing and testing. Those manifolds will be available for $300 to our customers assume they perform as expected.
It appears a larger turbine setups would perform better on factory manifolds, I will trail a SS2 in a .82a rear housing on current std manifold for some comparison.
how these going stao.?.are you still going ahead with a cheap steampipe bolt on jobbie?
i'm keen for another turbo, probally a ss2 with the steampipe bolt on if it goes ahead, and stick a gate on the exhaust
housing, just waiting to see how it pans out
cheers
darren
Edited by jet_r31
Yes I've fitted the prototype manifold. It is awful, lots of dressing up work required and i'm certainly not impressed with the level of workmanship, the final product I will be selling will be a steam pipe manifold with every thing done to specifications. it will definitely flow much better then a stock Rb25det manifold.
I've re-enforced the the joiner, that is where its likely to crack.
I'm pretty sure this is what some people sales on ebay. The bolt pattern on the flanges for cyc 4 5 6 are all out. it won't fit unless dressed up.
Finally fitted:
By the way any one needs their wastegate opened up? we can perform this service for $120.
    • Ok guys thank you very much. GCG highflow it is then 馃檪
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
