50cm?? Thats half a meter before.. Is there even half a meter of pipe from cooler to TB?
I'm sitting inside and haven't looked at it for a while, my judgement of distance is definitely off haha.
It's near enough to where the pipe comes through my cold air box.
You want it to be as close to the compressor housing of the turbo as possible. If your running actuator pressure you can also pop a nipple on the comp housing and run it straight from there to there.
Why is this, exactly? The only reason I can think of is to avoid overworking the turbo if your cooler is a restriction, but at such a measly boost level that I'm running I can hardly see that being of concern.
Actuator reaction.
If the surge is created by a minor overboost at those revs/throttle then moving the reference nipple will mean the actuator reacts quicker and can overcome the problem.
Thats assuming the surge is created by that specific issue.
Okay so the reply back from JJR is that all there dumps/front pipes are the same so mine was not a defective product.
No no What they are saying is, All my dump pipes are defective. You like you buy.
Edited by GeorgesR34
I might look into having that done then - would the turbo need to be removed to put a nipple on the outlet though? I would think this would only be for safety reasons to avoid metal shavings falling down to the compressor.
To make it simpler just get one welded on the cooler pipe as close to the turbo as possible.
Should work to the same effect mate.
Stao is it possibly you can produce these with a nipple on the cover from now on?
I was a little :( when I didnt find a reference nipple on mine but there were 2 casting marks indicating where it could be fitted.
^^this. I welded an 1/8 npt socket onto the underside of the pipe out of view then screwed a barb fitting in
cbf, lol. But yeah if (when) I next remove the turbo I'll have one put on the comp cover for sure.
Yes I have stock of the billet 20G but only in a 10cm T3 rear. I can sale you the core for $700 if you want, which you can run that in your current 8cm housing.
18G, and 25G plus 8cm turbine housings are still work in progress at this stage.
Ok , so what are the advantages of billet wheels compared to the ones on the one i have now? (just talking myself into it really, just seeing if i can justify the extra $$) the car that the turbo will be going on will be used mainly for track work so it will get a hefty work out!
Well if the comp wheel is made exactly the same to original caste then it makes no differences. lol
For our billet wheels we run a different sized hub with slightly taller inducer and blade curvature. All manufactures has their own wheel profiles, so there won't be an identical billet turbo result.
The currently 20G follows our SS hub and blade profile, that is engineered to produce the most Power with Least RPMs. So the car comes alive as soon as its on gas. You can see that worked extremely well refer to test result based on a SR20det None Vct motor, and no one has yet managed to get 200rwkws by 4000Rpms on same setup. Its going to be crazy responsive working with the Rb25det. I would expect the end result be similar to the SS1PU with more top end since working with proper manifold and external gate.
I reckon i might get a 8cm housing and one of these Billet 20G's and jam it on the 4AGZE Ke10 rolla i have here with some E85 in the mix..be epic on 30psi..lol
have a killer ex manifold here for one, be a shame to waste it..lol
cheers
darren
Edited by jet_r31
This is a pretty good result from a high flowed Rb20det turbocharger bolted on to a stock rb20det motor internally gated. Green is 98 and red id E85 limited by fuel pump. Hopping to see around 250rwkws with fuel pump replaced.
cheers
darren
For 4AGZE Ke10 rolla, Here's a result from a ATR28G2. Good chance cracking 300rwkws on 24psi on e85 :yes:
Just to ammend ur last post Tao, the red and green are e85 but hi and low boost. I will get an overlay of the 98 runs from before i converted it to ethanol
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
    • Is there an actual website thingie for peoples who don't have Facebooks? Cheers
    • All Jap Day is coming up again! 13th of July this year. Are you going? Tickets go on sale on Wednesday 6pm. Please let Quang know as well. https://m.facebook.com/photo.php?fbid=1163155775853542   I still get shit from my wife for this photo because it is the happiest she has ever seen me. And it's not with her, it's in someone else's car.   Quang's EVO is sick, but that rotary wagon flying past was absolutely bonkers.
