OH. I missed the bit where you edited my post.
IMHO difference will be next to zer0. All assuming the IWG isn't actually hindered by reducing it to a V-band out.
If the drain pipe is of concerns I would heat wrap the dump and put reflective race tape on the drain hose.
IMHO difference will be zer0.
Done already and so far so good. It's also to lowest part of my exhaust so was thinking about modifying it to be higher or make a dump in v-band and sell my bell mouth. Might just leave it and modify from dump backwards
So you not going to test the stainless mani remade in steampipe first before delivering a verdict?..i thought it would pick up
spool made in steampipe due to retaining heat better?
cheers
darren
I think you would find the stainless would retain the heat better than the carbon steel :)
Also thinking about this. Following the recent discussions on the JJR bellmouths not matching up to the gasket and possibly being a restriction, I decided to pull mine off to double check and low-and-behold, mine is the same. I could clean it up with a die-grinder, but I'm considering just having a custom dump pipe fabbed up, possibly in 3.5 or 4".
Stao, how hard would it be to convert the G3 Type-A rear housing from the OEM 6-bolt pattern to a V-Band or even 5-bolt flange?
Keep me in the loop if your going to get one made. Stao wants a photo of mine when I'm home to confirm rear housing model. Hopefully can just bolt on the rear adaptor
I ground mine out a bit and tapered the edges but still not 100% happy with it. It also has an inner skin that has lifted in sections prob due to the 1000c + temps it saw 4 years ago when it Chernobyl'd
Edited by t_revz
I also run a JJR dump and was very disappointed in the way it was when it arrived, I ended up die grinding massive amounts of metal out of it and had to reweld the flange as the pipe is welded inside.
But either way the car is going great with the high flow, I've done the first drift day in it (well 2 days, qr drift matsuri) and survived, even drove too and from the track :)
For a budget style drifter the high flow is perfect, I'm running stock injectors and around 210rwkw at 14psi.
The turbo and engine performed perfectly all weekend, and only problem was fuel surge on big right hand corners in third (surge and pump currently being fitted) and also killed my diff lol
Massive thanks again to stao
Anyone with an xforce dump want to compare for gasket match sake?
If we can identify a better dump stao won't need to make new rear housings for everyone
Well when you all get ready to sell your JJR dumps, someone PM me... I need a cheap dump...
Just saw they are only 180 in mild steel or 200 in stainless from just Jap. Cheap as
I won't feel bad hacking mine up now. Might cut a new flange at work and transfer it over
i think stao should offer his own dump to suit his own rear housing
then develop an iwg setup that works really well
if he can make a turbo for $1k then he should be able to knock out some cheap dumps
If you're gonna change the dump/flange pattern, you may aswell follow through, do it properly, and go external gate.. F*ck it, why not get a 6 boost while we're at it..
Perhaps this is why Stao makes these turbo's the way he does (Affordable and simple).
^ Exactly.
One of the best things about a HG is that it bolts on and is zero hassle.
Photos of Stao's adapter next to an OEM gasket shows his machine work is second to none and is as good as it can get in terms of being matched to the gasket. You cant ask for better.
Now that we know that JJR quality has gone down hill for the 1 piece dumps all we need to do is find an alternative. My money is on the Xforce.
^ Exactly.
Mine is 3 years old now, so I wouldn't say it's a thing that has happened recently.
Why does changing the flange pattern mean you should go external gate? I don't see how it makes anything harder? Right now you buy a HG turbo, and it's pretty much a requirement to have a dump pipe as well if you want the numbers. So you need to buy a turbo and a dump in either situation, why is it any harder to have a different flange if it's coming in a package?
    • Yep, yeah would need to do the flywheel although the 6 bolt NA clutch can handle a 20de if just wants to replace the stocker.
    • No it's fine. Heat sleeve is a thing. With oil running through it it is unlikely. Engine off heat soak can be a thing though. There is no way that you have a leak through the hose. That has pressure behind it and any small hole will turn into a large one in very short order. It is so much more likely to be leaking from the connection.
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
    • Hi all. So one of my major issues at the moment is my rear turbo leaking oil on the exhaust (and the general area). I presumed it was the rock hard super old drain hose, which it was not. So now I am in the midst of removing the rear turbo to get access to the banjo bolt that goes into the turbo oil feed. As one of the previous owners accidentally? tore off the OEM oil feed hardline that reaches behind the turbo, they ran braided lines directly to the turbo, presumably PTFE. Now, regardless if the line has rubber or teflon inside, is it just generally a bad idea to do this? I imagine these lines get quite hot being between the engine, turbo core and exhaust manifold. I suppose it's not too far fetched to think the line may even have melted. I'd love to hear your opinions on this as as the replacement OEM hardline piece is 130 per unit. And cutting open the currently mounted line to see inside will mean I just have to get a replacement either way. So far I am hoping maybe the bolt just loosened or (god forbid) they forgot one of the crush washers.
