Hey Stao - if my AX53B70 ever goes kaput do you think you could make something up for me with the housings off it? It looks like it could do with a couple more mm in the both the compressor and turbine wheels. So far it has been nothing but rock solid but I only use at 1bar max. Thought I'd ask as I wouldn't mind pushing it a bit more.
I'm only looking for 250-260rwkw, I figure the turbine housing on this would be ideal for that power level.
Edited by simpletool
Yeh well I wouldn't expect it to be a hell of a lot, but considering I'm chasing a restriction in my setup somewhere, I just want to know that everything is as good as it can be.
Run it without a dump pipe :whistling:
The problem with large internal gate is boost control. means it will have more boost tappering off in general as there will be more load on the actuator. It is a bit of a concern on the new .82 IW housing assembly, might need to run a 2~3 actuator setup or some thing similar to eliminate boost drop.
one off 38mm internal gate SS1 turbine housing.
Have big gate keeps the turbine housing cooler, but harder to boost control. how ever also depending on applications, we do get XR6 BA turbo waste gate jobs often. From my past experiments bigger gate drops more boost. How ever that was before the innovation of all the wastegate controlling methods that I've used today, So might not have the same drop behavior, while makes more power on lesser boost just like having an external gate.
And yes the machined 3inch Vband adaptor fits All .63 and .82 ATR43 series.
With way too much time on my holiday in Japan to catch up on some reading and not spending as much as anticipated etc I've made a list of jobs to do hopefully before end of the year.
Buy an Adj ex gear and dial in both cams as they are both currently retarded.
Modify or change dump pipe til it matches turbo perfectly. Awaiting Stao's results currently on new v-band piece.
Quieten down rest of exhaust
Section off pod filter and set up a cold air intake
Swap internals of plumb back BOV as I blocked atmo port but it keeps reverting. Need recirc port to open first.
Gas up air con.
And for good measure install WMI :whistling:
Will order bits tomorrow so it starts arriving as I get home :)
We were able to round down the edges right up the gasket.
But unable to open her right up as the walls were getting thin.
Yeah prob only 10mm
She'll be right! Still much better than before!
Should get tuned by Trent next week so will see how the results go
Please let me know your date, I would like to come and witness your tune and take some video footages. cheers
No problem will do!
Getting a mechanic friends to do the work out of hours so could be a one or two weekend job, pending if things go to plan or if we have time.
Haven't booked at exact time with Trent yet but he said he could squeeze me in any time. But will let you know!
Did you get a genuine nissan gasket from JJR for the dump pipe too Tony?
Yup got a genuine turbo gasket set but not from JJR. Including the gasket from the turbo to dump pipe.
Parts to go on this weekend:
  • SS2 Turbo
  • Manifold from Stao which has been opening up a bit for better flow
  • ID 1000 Injectors
  • 3Inch JJR bellmouth dump pipe
  • Cometic plenum gasket (When I do the injectors)
  • Cometic manifold gasket
  • Genuine turbo gasket kit
  • New nuts and bolts
I'm not sure if the stock R34 plenum gasket is rubber or not. you need to get the metal one with rubber O rings in them. I found the rubber ones gets blown out under high boost.
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
