I'm not sure if the stock R34 plenum gasket is rubber or not. you need to get the metal one with rubber O rings in them. I found the rubber ones gets blown out under high boost.
Cometic plenum & manifold gasket are both steel :thumbsup:
Yup got a genuine turbo gasket set but not from JJR. Including the gasket from the turbo to dump pipe.
Parts to go on this weekend:
  • SS2 Turbo
  • Manifold from Stao which has been opening up a bit for better flow
  • ID 1000 Injectors
  • 3Inch JJR bellmouth dump pipe
  • Cometic plenum gasket (When I do the injectors)
  • Cometic manifold gasket
  • Genuine turbo gasket kit
  • New nuts and bolts
Power coming at ya.
Just bought water meth for my SS2 so maybe ill see you in mine....unless your going on e85 :(
No e85 here
My car is still my daily
Would like to be able to go on road trips without 6 jerry cans in the boot :P
Hence me using water meth.
Tank should last 1 tank of fuel on the track or 3 months on the street :)
On this note I have a nice little kit I would like to sell ;)
Come at me bro!
I looked long n hard and thought about hitting you up but unfortunately and no offence but it was my least preferred kit.
Each to their own, but thanks for helping my cause :P
I had planned it for a very high comp DE+T setup, but since then went about forging my DET instead.
So its fairly redundant to me now as my SS1PU will do what I want it to do without the WMI.
Hey Stao, do you have a comparison dyno graph of the G3 with original rear housing flange and the type B one I got from you?
Goto
www.hypergearturbos.com
Under ATR43 and there are dyno readings from both Type A and Type B rear housing from the G3.
Goto
Thanks. If I'm changing from type A to type B, do I need to get a new gasket of some sort for the new flange to go on? I just want to make sure I have all parts ready for the swap over.
I'll have a new dump pipe gasket & new dump pipe, so I mean between the turbo rear housing and the flange plate itself.
Edited by copycutter
LOL thats a good idea. In practice I am told its like having E85 on tap - which helps those who don't have the stuff available.
For me my entire car hits a whole other level of money, time and effort at anything above 240kw. So instead of going for my ultra responsive 10:1 CR 240kw on WMI I have gone for an SS1PU with a DET motor instead. I think I will still get what I want with a little less off boost punch.
The WMI kit would make my setup even better Im sure, boosting power to 280odd shouldnt be an issue.. But the issue there is that SR gearboxes arent so 280kw friendly and neither is my near new clutch. So rather than reinvent the wheel I have worked so hard to create I am just going to enjoy my 240 kw and sell the unused WMI kit.
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
