Stao tried to seach and find the answer because I think you have told me before.
But what do you think the limit of the SS1PU would be on water meth injection.
Mine was limited due to the heat.
So in the future once I save the dollars I will be going that route.
But at the same time dont want to find it hits a wall at like 260rwkw
The R33 highflowed turbos would support up to 240rwkws while R34 turbochargers can be high flowed to support 260rwkws. response wise high flowed R33 turbo is about 300RPMs earlier. Personaly I prefer to run a highflowed R34 turbo
  On 21/11/2012 at 9:53 PM, GTScotT said:
Actual water meth (50/50ish mix) will get you results similar to E85 if implemented right.
Yet to see any E85 results on the ss1pu
If you know of any then I would love to see.
Just want to know what to expect if I do it
  On 21/11/2012 at 2:02 PM, t_revz said:
Prob just me or the photo but v band doesn't look 3.5".
Plus I thought Stao told me once he could only do 3" max.
I thought it was 3.5" cause we were talking about a 3.5" dump. But if its 3" im not worried, makes it easier to get the dump to fit to the turbo anyway
Based on the spec of the thing it will lay close to 300.
I'll give you a good deal on my WMI kit if you want to be the first to try. Not trying to be a viral sales kent.
Pm me prices and details of the kit
Don't know to much about them but would need one with a good fail safe
I fitted one to an M35 in the stock housings that managed 300, not a good indication of what it would do on an RB but it should be close.
Good to know Stao has done a nice job with the turbine side of things. I can't wait to have mine running :)
How did it go on the VQ?
Still means it can flow that sort of power
Spoke to my clutch guy today and his going to get back to me if it can handle that power.
If it can't then I can't afford it
If it can then I will be doing that over Christmas
When in for a return tune today.
After a few runs the manifold pretty much overheated and split one of the silicon hoses so had to call it a wrap again.....
We got up to 283 rwkw before the silicon hose split
Tune as it stands atm:
I might try out one of staos dual actuators as its at 19.5 psi dropping to about 15.5 psi i think
  On 22/11/2012 at 9:24 PM, XRATED said:
What turbo is that Tony? Is it stock intake mani?
Cheers
Justin
Hey Justin its an internal gate ss2 turbo on 98octane
I got a one of staos china manifolds
  On 22/11/2012 at 3:06 AM, scotty nm35 said:
It moved nearly 2 ton down the quarter in 12.9, faster than mine as he gets boost on stall.
I think it hit 20psi by around 3k...
Thats very nice! Theres always a point where you can have a faster car with a lower number, which is something im scared i may have overshot by going the SS1PU on my SR but we will see!
Good to note that the unit is an all round good turbo though. Everyone who has one seems to be happy with it regardless of how much power they made (its only numbers anyway). Props to Stao yet again!
What fuel Tony? Its starting to shape up nicely (ignore the fuel question coz you replied yourself before I hit send)
21U @ 260rwkw on United E85. Only 14PSI as ter rear tyre can't handle more around the track.
This turbo has now done over 40 track days, including WTAC.
Responce..5th gear at 110 is pretty much on boost. Its over 100rwkw at 3000rpm on trents dyno.
Update on car.
Car is finally tuned:
R34GTT
Mods:
SS2 Internally gated Turbo
98 Octane
China manifold
3inch JJR dump & 3inch exhaust
ID 1000 injectors
Yellow jacket coil packs
Hybrid return flow intercooler
Scotty 3inch intake
About 190rwkw at 4,000 rpm so happy with that!
About 20psi falling over to about 16psi i think
Note this is a conservative track tune
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
