I bought another hypergear last week, going to start fitting maybe next week, i bought all the gaskets today except
for upper intake manifold gasket for when i change injectors, are R33 gaskets the same as R34?, i wanted to get a Cometic
cheers
darren
g3 type a..but i will put a 3000rpm stall in it, so it won't
Be laggy at all, the only thing i cant decide is if i will put a 38mm gate on
housing, i have one here but i dont know if i cbf, the idea behind getting the hypergear
in first place was so i could do a quick turbo change and get on with my
projects instead of f**king around with family car, i just wan
t enough power to pass safely on holidays 300awkw would be enough
Edited by jet_r31
cheers
darren
Careful with that gasket
All the cometic ones on ebay say they fit r34
But they dont. Got one sitting at home cuz it doesnt fit
Hence me asking you guys....ebay says it does, my mate say it doesn't either(and he should know, but
i wanted to double check) , looks like acl race series i think does them
cheers
darren
FYI
Cometic on the bottom
stock on the top
Lol meant to say AREN'T.
Stao I had to rotate my CHRA for better fitment which wasn't an issue but have noticed the actuator arm is actually too short.
I have it set to maximum adjustment and I am only getting about 1/4 circle of preload when I would like to have 1/2 at minimum.
is there a slightly shorter actuator I can use or is this it?
I have moved the mounting bracket and bent it a little to help but I do not want to go too far with it.
It was fine prior due to the angle the chra was on as it gave more distance, but then my oil drain was fouling the drain entry on the block.
I ended up scoring an R32 collector gasket. The R33 one is all rubber where the R32 one has a metal piece sandwiched inbetween the rubber. May hold up better with higher boost like Stao was saying.
    • Install a MAP sensor pre and post throttle. Best data you could have for NA, then play with the bends and/or air box and see how much of inflection is created at WOT on the plot.
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
