Stao what are the changes to these new SS1 and SS1.5 compared to my current SS1PU?
Can you please confirm sizes. Feel free to PM if its better.
SS1 is in 60mm, SS1.5 is in 64mm, while SS1PU is in 71mm.
Both wheels has 3mms in tip extension, customized hub.
The 60mm wheel has the equivalent blade size as the current 71mm cast wheel, and I've added couple degrees crop to the top so it won't be maxing out so early working with a Rb25det. This wheel should be excellent for people targeting 200~240rwkws on stock camed Rb20det/SR20dets.
The 64mm is a smaller version of the 71mm, how ever there isn't a lot of difference to the inducing and exducing area as most of that diameter has been taken out form the center hub, it does have very sharp throttle response, probably won't have as much top end, hopping to see bit more areas under the curve.
Went to a quite spot today and spent some time modifying the top left corner of my map as its caused some issues since dialling my cams in. I then added a bit of fuel across the entire map so I could open it up.
It used to hit 10psi at 3550, 14psi at 3800 and 17 at 3900
Today visually using rpm on controller and gauge I saw 14psi at 3500 and 17 at 3700. My controller is at 17 currently so it might have built more if it wasn't already tapering off.
Stao's 98 result on stock mani was 14 @ 3450 and 17 @ 3550 so I'm right there with him now. Just waiting on exhaust to be built and for me to make a cold air intake before retuning :)
Edit: oh and for me to wire up the water/meth controller
Edited by t_revz
Just thought I'd post to say that I got my car tuned by Toshi today and my god, the ATR43G3 is an amazing turbo. The response and power is great and I'm only on 16psi. Only did a road tune so I dont have power figures but I'm satisfied.
When I get it on the dyno I'll throw up a print out
Thanks for the feed back. And Happy new year to every one, Best wishes and more power cranking.
in photo is our OP6 high flow using SS2 CHRA:
Balanced using our brand new Dynamic turbo balancing machine with VSR cradle.
Stao I've been meaning to ask, what CHRA do you normally use in your 2IU highflows?
Also, my SS1PU SR is booked for its tune on the 15th. Hopefully a healthy result coming soon.
Thanks Stao, thats pretty cool info :)
Might try get a friend to consider one. I have had a lot of other people tell me the 2IU highflows you make work REALLY well. Testament to your work. I was just curious about the specs.
Yes can be done. Can also balance RC plan rotors, and remote control car wheels. lol
Further update, this is relation to current bearing setup. I'm trailing couple of high tensile steel ball bearings, as well as few different types of brass bearings that I've made earlier. Will upload result once done.
Nice looking BB cartridges Stao. Do you expect the BB's to make a huge difference? I've used bush and BB turbos before, but never seen back to back comparo of same turbo from same maker, so I'm very interested to see it.
Doesn't make much differences on the dyno. but in road driving there is a small difference in throttle response. how ever I'm pretty concert with the life span with those bearing specially when they are working in a hot environment with high speed and heavy thrust load.
In the bush bearing setup the centripetal and thrust support is the oil pressure supported by oil pump. So the bearings don't necessarily worn unless the pump fails or the oil has hard objects. I'm trying to get the same throttle response as the roller bearing through modifying oil galleries on the bearings and bore.
Can be done. Result in page 320. How ever only for evaluation at this stage.
Trent is Finally back, should have results for all 3 new turbochargers by weekend.
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
