Stao what are the changes to these new SS1 and SS1.5 compared to my current SS1PU?
Can you please confirm sizes. Feel free to PM if its better.
SS1 is in 60mm, SS1.5 is in 64mm, while SS1PU is in 71mm.
Both wheels has 3mms in tip extension, customized hub.
The 60mm wheel has the equivalent blade size as the current 71mm cast wheel, and I've added couple degrees crop to the top so it won't be maxing out so early working with a Rb25det. This wheel should be excellent for people targeting 200~240rwkws on stock camed Rb20det/SR20dets.
The 64mm is a smaller version of the 71mm, how ever there isn't a lot of difference to the inducing and exducing area as most of that diameter has been taken out form the center hub, it does have very sharp throttle response, probably won't have as much top end, hopping to see bit more areas under the curve.
Went to a quite spot today and spent some time modifying the top left corner of my map as its caused some issues since dialling my cams in. I then added a bit of fuel across the entire map so I could open it up.
It used to hit 10psi at 3550, 14psi at 3800 and 17 at 3900
Today visually using rpm on controller and gauge I saw 14psi at 3500 and 17 at 3700. My controller is at 17 currently so it might have built more if it wasn't already tapering off.
Stao's 98 result on stock mani was 14 @ 3450 and 17 @ 3550 so I'm right there with him now. Just waiting on exhaust to be built and for me to make a cold air intake before retuning :)
Edit: oh and for me to wire up the water/meth controller
Edited by t_revz
Just thought I'd post to say that I got my car tuned by Toshi today and my god, the ATR43G3 is an amazing turbo. The response and power is great and I'm only on 16psi. Only did a road tune so I dont have power figures but I'm satisfied.
When I get it on the dyno I'll throw up a print out
Thanks for the feed back. And Happy new year to every one, Best wishes and more power cranking.
in photo is our OP6 high flow using SS2 CHRA:
Balanced using our brand new Dynamic turbo balancing machine with VSR cradle.
Stao I've been meaning to ask, what CHRA do you normally use in your 2IU highflows?
Also, my SS1PU SR is booked for its tune on the 15th. Hopefully a healthy result coming soon.
Thanks Stao, thats pretty cool info :)
Might try get a friend to consider one. I have had a lot of other people tell me the 2IU highflows you make work REALLY well. Testament to your work. I was just curious about the specs.
Yes can be done. Can also balance RC plan rotors, and remote control car wheels. lol
Further update, this is relation to current bearing setup. I'm trailing couple of high tensile steel ball bearings, as well as few different types of brass bearings that I've made earlier. Will upload result once done.
Nice looking BB cartridges Stao. Do you expect the BB's to make a huge difference? I've used bush and BB turbos before, but never seen back to back comparo of same turbo from same maker, so I'm very interested to see it.
Doesn't make much differences on the dyno. but in road driving there is a small difference in throttle response. how ever I'm pretty concert with the life span with those bearing specially when they are working in a hot environment with high speed and heavy thrust load.
In the bush bearing setup the centripetal and thrust support is the oil pressure supported by oil pump. So the bearings don't necessarily worn unless the pump fails or the oil has hard objects. I'm trying to get the same throttle response as the roller bearing through modifying oil galleries on the bearings and bore.
Can be done. Result in page 320. How ever only for evaluation at this stage.
Trent is Finally back, should have results for all 3 new turbochargers by weekend.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
