So, went and had a bit of fun last night. First time down the quarter, shit is hard :glare: Got 5 runs in and got better each time, first run was a 16.55 missing 2nd and 3rd :P PB was 14.1 @108.5mph on my last run. I think I could have got into the 13's if I could have had a few more runs, and possibly matched Luke's 109. I need a lot more practise though, and shift lights now make sense to me. Was hitting limiter in almost every gear :/
Was that with 360whp? Those trap speeds are way lower than I would have expected!
Yeh round about. I do think I could have picked up a bit of speed, my first run was 104mph and improved with each run. I'll get onto a weighbridge sometime and see how close my dyno reading is to my trap times.
I'm thinking going big in turbine and going smaller in comp. Need a large turbine to make power using stock manifold and internal gate, Then reduce comp dia to compensate for response.
R33/R34's with stock turbos and high 200rwhp trap at around those speeds. I would have expected more around the 115mph with that power
Pretty annoyed they failed to give us any of that info at the SAU Nats. Been chasing them for ages.
Whole reason I did it was to get some trap speeds and some times. All I currently have confirmed is my 800m time which doesn't do much for me
Well I'm no drag racer by any means, last night was my first attempt. I had hoped to be closer to 112, but I've got no idea what I was doing right/wrong so I was just trying different things and was getting faster with each run. Aside from me being a terrible driver, what else does it come down to? The car being off wouldn't surprise me, it's the laziest RB in existence. But I've been on the dyno at Allstar, Hyperdrive, Autoworx and Garage 101 and they all give me a big number, so are they all off?
What is boost recovery like in gear shifts? Does your car have a screamer pipe? Hard to tell from the clip
Yeh gate is currently venting to atmo.
Boost recovery seems ok, though last night was the first time I've driven the car since it was tuned in September (aside from Powercruise which was the day after it was tuned).
Thought it sounded like that, seemed to take quite a while to come on in first and a it didn't sound like it came to life in a huge rush in second either... Obviously hard to tell watching the clip but it got my attention. If you spend a reasonable amount of time building boost when raving then you don't get the full power curve the dyno suggests that you have at your disposal.... Which can definitely affect real world performance, ie lower trap speeds than expected for a power level.
Well it tended to be like that in 1st with the pro-tree, I wasn't getting off the line very well and bogged down a fair bit in 1st. 2nd is hard to tell cos the V8 next to me starts to make a bit of noise. From memory it was straight onto full boost in every other gear though... I'll have to take it for a drive and pay attention to the boost recovery.
What would that indicate though? At the moment I'm aware I have either a restriction or possibly a cam timing issue.
Edited by Hanaldo
Well my car on 250rwkw pulls 121mph trap sipped while it's a 180sx it's shouldnt be much different maybe 2 or 3 mph your cars definately not making 360rwhp not now anyway
Even if you bog down at the start it won't affect your end mph trap speed much if anything might be alil higher the faster you take off or better 60ft you get the lower your trap speed will be
Me bogging down at the start with 2.3 60ft still got a 12.5@121mph with 250rwkw so either Unigroup has a low reading dyno or your car is low on power
Yeh I know the start wouldn't affect the trap time much, I was just discussing the boost response. My problem further up the track was shifting at the right time. I can't remember how I did on that run, but I may have hit limiter in 3rd which I did pretty frequently. Though I guess that still wouldn't account for ~10mph slower.
Love my car :D
Just shift earlier...higher gear means higher mph ...shift where power drops off on the dyno..or if power isn't dropping off to after 7k raise your limiter and shift at 7k..in my car power dies around 6500 so that's when I aim to shift...
Good on you for getting it out there. :thumbsup:
??? some one already done a 73MM? The blade profile will be totally different either way, but thats ok, I can make the exducer into what ever dia to archive the same goal. Sierra wheels are bit old school, they were retired from our turbos since 09.
Using Brae high mount now. Ebay manifold is off the car.
LOL, I have a 73HTA TD06L2 :whistling:
My limiter is set to 8000 and I was trying to shift by 7500... But I don't have the coordination to watch my tacho at that speed! Haha.
I was actually catching most of my opponents by the end of the race, and they were running 13's/high 12's.
Altering comp wheel size little over or under makes no differences, it doesn't mean it has to be a 73mm, I haven't never seen their turbos before, so blade profile will be totally different. Any results from that on a Rb25det?
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
