so you are changing the compressor cover profile?, if it works you can mod all other G3's for a cost?
i started to fit mine last night, but will take me a month or 2 to do as i am modifying the whole car and only have 3-4hrs
a week to work on it, so if this works im interested
I was confused as in your picture, you have the a comp wheel and housing, and above it is a billet wheel by the looks..
cheers
darren
Edited by jet_r31
Its the profile in the housing. will still be using original cast G3 comp wheel. So the modification can be carried out on any G3s easily (or freely).
The billet wheel was from a SS3 I made a roller version of that as well.
no worries. So do you want as much power as possible out of it or preferably stock response?
i want great response mate. dont forget im rockin an auto so lag will kill me. love it to come on boost early with great midrange.
let me know your thoughts!
Ok I will use same profile that I've done for ssxricho, it will have very similar response to stock while produce more power and torque with a very wide power band.
Dyno reading and reference is at:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page__view__findpost__p__6352727
Results from Ball bearing G3 with updated comp profile:
E85 high mounted externally gated: Maxing out at 365rwkws
VS the older G3:
I've also done one more run with the The ATRSL25.5G. Little bit pissed as I'm missing 1KWs reaching 400rwkws. Maxed out at 399.1rwkws. Need bigger cams for the full potential of this turbo. Still, this is the highest power ever archived on stock cam from Trent's dyno library.
Its actually very fast, the power delivery is so gradual theres hardly any wheel spin. I'm getting some mickey thompson drag tyres and hitting the strip soon.I think this one can get into the 11sec mark
Lol awesome!
Also glad to see an ss1pu trapping good speed! Good work Daniel!
Haha I think it's not a great indication, everyone keeps telling me its an insane mph.
Also that the airport is way way different to the actual drags
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
