I've been running the BB G3 with the latest comp profile for about 1000KMs so far and it appears to hold together well. I can swap this one with any G3 owner for free. PM me if interested.
Dyno results of standard and latest BB unit:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page-352
result only shown difference in 4th gear to floor. the transition and throttle response between the two is quite different.
looking at running water meth injection, whats a safe boost level for the tATR43?
You can run till it stops making power. Around 24psi
Hey Stao do you mean even my thrust bearing g3 can be updated to BB aswell as the updated comp housing?
Yes I can rebuild your bush bearing G3 into ball bearing and updated comp housing. in this case I will swap you with the one that is currently in my car free. I will need your turbocharger back for a day or two for a small modification on the turbine housing as well as the comp housing.
The ball bearing update can apply to all Gx, Gx based Rb highflows, SS2, and SS3 turbochargers.
Hi all,
Went out to WSID last night to run the car for first time since my PU highflow.
First run was a 13.2 @ 115mph with a rubbish 2.2 60ft
Second run does not bear a mention and then it PISSED DOWN RAIN
I was really hoping to bust into the 12's but im not sure it (or the useless driver!) will manage it.
Anyway, just thought id share that with the internets
It dyno'd at 280ish rwkw but it does feel a little down on hp. That being said i did have some problems with traction off the line.
What sort of trap speed should i be expecting assuming the 280kw?
Well to get fast time you will need small rims with fat simeslick tyres (hint from Trent), I used to skit all over 3rd gear with a G3 on my road tyres and that was a slow 330rwkws. Run RSRs or better will help heaps.
After doing abit of reading on the net, its not a bad time for a stock weighted R33 internally gated, stock manifold on pump 98 at that power level, there is a huge difference in mid to top end range torque with high mount and external gate after 120km/h. But I don't know how the car run slower and slower after each pull.
Also G3 is changing, I will post some photos of the latest G3 tomorrow, in hopping for the same power level with much better throttle response, it will also be equipped with the latest bearing and lubrication setup as well as optional ball bearing.
Hi all,
Nice, sounds on the money to me. I did 13.3 @ 112mph off a 2.2s 60ft with a bit less power on street tyres on an airstrip with my GT3076R. Put stickier tyres on it and ran 12.6 @ 112mph off a 1.9s 60ft (same strip, same driver... I was still learning how to make it work, not great traction) - it took me low 2.0s 60fts to get into the 12s from memory so not far away.
I reckon the delivery of the turbo plays a definite part in the ET, and the on-off responsiveness between gears in the trap speed and ET for sure. The G3 as Stao says has good 'rush' up top, but a little lazy in and out of gears (on stock manifold low mount I mean) and kind of like a light switch delivery in 1st and 2nd which makes juggling bog/wheelspin hard off the line.
And obviously driver experience at the strip :P
Yeh I think Luke's and my trap results are very effected by boost response between gears. Took the car for a drive the other night and tested that out, and I've got about half a second to a full second of lag between each gear change.
You will find the BB G3 with the latest comp profile changes that power delivery behavior by a lot. It smooths the power delivery pattern, which takes out that big launch behavior, sticks the car on the road better.
That lag you explained would absolutely kill mph, if its that bad...glad im auto..lol,
looking at the G3 drag vids, they do look lazy
cheers
darren
Edited by jet_r31
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
