guys FYI the following is 400 bucks delivered:
http://www.ebay.com.au/itm/261045441228?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_1390wt_1397
that is a GTR item which will work on any 240mm push type nissan clutch, RB25/SR20 included.
the clamp load is 1100kg so 300kw shouldnt be an issue. drivability will be as close to stock as possible.
hope that helps, NPC are good but you will be stunned @ the price.
Hey Scott,
I think those are the Exedy HD (re-manufactured pink cover ones). The Exedy Sports (silver cover) are the ones you want, the pink ones are terrible, I have had one before uneven wear on the friction plate not to mention you often hear people complain about them on various forums. And pedal feel of Exedy vs. NPC, Exedy pedal is super heavy not to mention people end up breaking pivots as well.
Hey Scott,
The re mfg pink cover is made in Australia, the rest of the world gets the japanese MFG silver cover item. That clutch is coming from the UK.
You can also tell by the box where it says 'exedy racing clutch' with Daiken logos. Where as the said pink cover clutch will come with the ghey 'sports tuff' box.
Excuse my ignorance, but is clamping load all that determines if a clutch can handle a particular power level? I would have thought power delivery, torque, driving usage type etc all affects it also??
The friction material itself obviously affects the amount of torque that the clutch can transmit. If you have a higher coefficient of friction, you get more grip out of the same clamping force. The detailed design of the clutch affects the way that the raw clamping force is distributed across the plate(s), which will also affect how good the clutch is. Simply think of that as the clutch being 95% efficient, or 85% efficient, depending on how well it uses the total clamping force available.
Clutches can be (and usually are) generally "rated" at a certain power level on a given engine because the diameter is essentially fixed across most clutches for that engine and the torque/power delivery variables are almost fixed. Move the exact same clutch over to some different engine and the rating might have to be tweaked. If you take driving style into consideration, then the "power rating" of the clutch assumes a perfect driving style and you would sensibly de-rate the clutch for any non-perfect driving (whether that be the usage model or the clumsiness of the driver, etc).
Yeh start doesn't affect mph much.
Well. Guess that explains our runs at Powercruise. Either we are both hugely down on power, or our turbos are extremely laggy between gear changes.
I say laggy between gear changes.
Im pretty sure if i got a good run i would most likely do around 14.1
Am i changing gears wrong? should i be flat footing the whole way and riding the clutch in gear changes lol???
101mph? That'd have to be a HELL of a launch etc to do low 13s or 12s off that, with slicks at least. 101mph is reasonably typical for high 13s/low 14s on a clean run. What power and type of car are we talking? With reasonable spool I'd be expecting under 200kw from an R33 - if it is much over 200kw then its not a driver issue, it is something to do with how the power is delivered (which could include how much power there is).
I will take mine to the drags after i get my turbo back from Stao and retuned. See how it likes ~6000rpm clutch dumps on MT's
thats it, teach that c*nt a lesson
hopefully i can borrow a go pro and can video me trying to rip the gearstick out the back window (as said by Jez himself on a prior test drive)
    • Hello First, I apologize if this is not the correct forum. Let me know and I will move it to the correct one. I'm having a problem with the tachometer on my Skyline R33 with an RB25DET Neo engine. I'll tell you from the beginning. I'll tell you from the beginning. I have the RB25DET Neo engine installed in a Nissan Patrol GU, with a Link G4X control unit specifically for that engine,  and I have fitted a Skyline R33 tachograph to the original GU dashboard, but it doesn't work properly. I have the tachometer connected to the positive and negative terminals of the GU panel's wiring, and the signal cable is connected directly to the ECU output pin, but the rpm fluctuates widely. Can anyone tell me if the output signal from an R33 ECU is the same as the output signal from an R34 ECU, or if the voltage and signal type are different? Regards and thanks.
    • I guess it was the thought about "Oh if I were to drive this everyday". Then no, SL500 I wouldn't really consider lmao.
    • Yeah actually really fair point. Idk what I was thinking when looking at the SL500. Now that I think about it, I feel like I would have more enjoyment out of a shitbox that I would need to repair than some fancy merc. Although I must admit the SL500 does look quite nice. My bad hahaha.
    • 100% Also "Not wanting to spend money" is THE WORST IDEA IMAGINABLE when coming to a project car of any kind. They EXIST to BURN MONEY. Sure, gas money is a thing. A stock car with the worst fuel economy ever sold would probably be cheaper than modifying a car with FREE petrol for the life of your ownership of it, lol.
    • Amount of time you're being observed by law enforcement is so minute, that you could be a dumb shit 90% of your driving time, and never lose a demerit. You could also be the best driver ever and still get hit with a fine.   When you realise how quickly everything turns from "Wee, we're having fun!" To "oh f**k oh f**k oh f**k", you start to realise the only way to be a good driver, is to not be doing anything dumb or unexpected by normies on the road. You want to go fast, go to the track. Someone there in a 1990s slow POS will also show you how bad of a driver you are as they lap 10 seconds per lap quicker than you can in a car that should be considerably faster.
