Gee by the time I get my car 100% there's gonna be 100 new better turbos available.
Keep up the good work Stao!
If its off the car you can send it back to me for a update. The main difference in the SS2 would be the Type B rear housing and compressor housing.
Just came back from Drags :)
Very very happy
I can confirm its driver error that's causing my low times.
I think i could get a low 13s ( or a better driver )
Got a 13.822 @ 171.3km/h
Around a 4k launch
FYI
ATR45G2.5 is my turbo @ ~340hp
Very very happy
Around a 4k launch
FYI
Low 13's is definately possible, however 106mph means you aren't anywhere near 340rwhp.......
What have you changed in this new ss2.5? Is it a turbine change?
PM me if you would prefer
That BB SS2.5 has a larger turbine, that is only good for high flowing use. getting it back on the dyno Monday. The prototype SS2 had a different set of blades, making minor changes to boost ramp behavior.
I ran that exact time and speed with an S14 making 175rwkw with stock turbo.
my 60' was 1.8.
Unless your 60' was like 2.2 or higher and you missed gears a couple of times, it will be more than driver error that's the issue.
my 60' was 1.8.
Wow that's a huge difference in power
How much experience did you have prior to this run?
I don't know about 115mph, but 106mph is way low for ~250wkw. Quite an odd pattern forming!
Not wrong there, all the drags results are showing that you would be better off with a stock turbo.
First and only time at drags.
Got 4 runs.
first one was a 14.4 then eventually got 13.8 on the 4th run.
I kept shifting at 7K (silly in an SR) and would just touch the rev limiter in 3rd as I crossed the line.
Could have possibly been quicker if I shifted earlier but never got to go back.
Car was a series 1 S14 with heavy 17s.
255s on the back with pressure reduced to about 22psi
Stock Clutch, FMIC, 1 bar boost, pod, exhaust and tuned SAFC II
Done by Yavus at Unigroup
175.4rwkw
Stock turbo and clutch do make it easier to launch more consistantly though.
And the SR20 is a different torque curve to the RB so possibly easier to control wheel spin.
Edit - I should take my current car (stock RB25 R32 gtst) to get some base times.
Edited by TTT
Seems to be pretty normal
I did 13.32 with 112Mph that was stock weighted R34 with a pu high flow 280rwkws on street tyres. Stock turbo run 14.6 with 98mph on 12psi with 200rwkws
Edited by GeorgesR34
Just to show you how off your figures are. My non turbo 300ZX trapped 97.6mph with ~130rwkw, yet your R34 had "200rwkw" ;) Trap speed tells no lies
Can a turbo perform better on a dyno than on the road?
Like could two turbos that makes 250rwkw with the similar power curve get totally different results on the road.
Very easily, what i don't understand is how these turbos keep underperforming on the drag strip.
Edited by Super Drager
Punching your 97.6mph trap speed into a drag strip calculator - to only have ~130rwkw you would need to be weighing around 1315kg - the 300zx non-turbo (from my googling around) is around 1460kg without a driver. That's not an insignificant weight difference. Not questioning you - just curious :)
Was going to say that - my Prelude needed around 130kw to pull 96-98mph trap speeds and weighed ~1330kg as raced, must be an ultra low reading dyno to do 97+ with a "130kw" 300ZX.
I'd hope for over 98mph with 200kw in an R33 too, though.
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
