I would be interested to see inside the bore, and perhaps the plugs tips if they are still there. I too noticed the dint in the backing shield, dare I say Det damage? It looks like it's been blasted by hot metal particles.
Can a turbo perform better on a dyno than on the road?Like could two turbos that makes 250rwkw with the similar power curve get totally different results on the road.
I think what's happening is we are making the power but have a lot of lag between gears. On a dyno you're loading it up in 4th,so you don't see the difference between gears, but at the strip it makes a huge difference.
Now that I have the gopro hooked up I might test this and record the time to build boost back up.
I was completely oblivious until Stao rang me about it. The plugs were fine, the motor doesnt miss a beat and I havent seen any oil being burnt.
Unless some of my valves or pistons are missing chunks and somehow continue to run, i was thinking maybe some slag or something has come away from within my exhaust manifold and caused this.
The launch control probably doesnt do the turbine any favours either. :whistling:
Wait I thought this was stock manifold, what manifold is it for slat to let go?
I ask because ive seen a known brand manifold do this to a kando recently.
I met you at a trackday a while back.
Wasnt yours the car with the bolt-ons from another car (turbo, intake manifold, injectors etc etc) as well as the ECU. But the ecu was tuned for those mods of the bolt ons in the other car and you hadnt bothered to get it tuned again to your car, you just hooked it and and went from there.?
If so then some decent DET might have been occurring methinks...
Sorry you have me confused for someone else. I have an ATR43G3, standard plenum, nismo 550's and ViPec ECU.
I don't know about 115mph, but 106mph is way low for ~250wkw. Quite an odd pattern forming!
Thats stagea kw for mph..
I'm a bit lost, but most of the cars that have run the drags so far , are the ones that had problems on the dyno
anyway i thought, so i don't see a clear picture yet, Stao should go
cheers
darren
Edited by jet_r31
Was going to say that - my Prelude needed around 130kw to pull 96-98mph trap speeds and weighed ~1330kg as raced, must be an ultra low reading dyno to do 97+ with a "130kw" 300ZX.
I'd hope for over 98mph with 200kw in an R33 too, though.
That's what the dyno read and that's what i'm going off. I'd rather have the low reading dyno number and a good trap speed than the other way around.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
