good work guys. should make a nice improvement with a functional gearbox and grippier tyres. i thought RSR's were quite grippy but with 350rwkw maybe they dont stand a chance, especially with axle tramp going on.
vids next time? :)
Nice work on the strip :-) glad its now proven that the turbos can trap the speed.
now its time for others to revisit their setups and their tuners.
Indeed, those trap speeds are much more like what one would expect from those power levels... for the sake of interest, what kind of blow of valve is this car running?
Well done stao and status - must've been interesting having it try to swap ends in 3rd or 4th on the strip! :P
Can't wait to get this new clutch in and get back to the strip.
What tyres are you going to run next? Some semis?
He's getting axle tramp as said which wouldn't be helping things.
Stao as reference if you aren't running pineapples already you should get onto it asap.
My S14 has pineapples and does not tramp at all, while friends who don't have the pineapples tramp like mofo's.
Yep, i agree... I had bad tramp and put the collers (dunno how to spell lol) and it made a HUGE difference....
Tramp is less about pineapples and subframe location issues than it is about damping. I agree, locking the subframe up with better/newer bushes and/or pineapples is a big help and probably a necessity, but I would always look to the rear damper settings/health as my main concern when trying to fix tramp.
GtScott: Would great if you can pass on a link to those pineapples. I will have a look into them.
Been recommended to Mickey Thomson 16inchs drag tyres. Will need to source that and a set of factory rear rims.
I took few video footages in bystander area. Will upload shortly.
Yep 11's would be my guess..... And yes locking the subframe made a huge difference on my car but doesnt mean it will on all cars :)
I'm thinking what happens if run a 1.06 turbine end on the G3. it should take away all the zappiness down low causing wheel spin while kicking in mid top range while the car's rolling at much higher speed.
Noob question. Quarter Time stands for taken completing the run. Does the car with higher mileage stands for a faster car after the completion of the track? assume if the run way is 1 full mile instead of quarter mile.
    • How f**ked am i? what would happen if i leave the magnet inside there?
    • I'll update you guys when i get home from work, im going to try to fish it out.  I just realized that i can't even drop the oil pan. The whole front diff and axles are connected to the oil pan... is it even possible to drop the oil pan without taking out the motor?
    • So recently at the track had experienced a loss of throttle after a period of WOT after installing the emtron ecu, recently did some logging to troubleshoot the issue and found the ECU was cutting due to a low oil pressure issue. Going over the log can see that while accelerating at 4k rpm will see 100 PSI of pressure and holding steady at that level until getting off the throttle which then after can see as low as 25 PSI at 3-4k rpm and will recover back to a normal level after that.   Wondering if anyone has an idea what could be the cause as it just feels abit strange and i dont feel like it could be a sensor issues just due to it clearly sitting at a good pressure until off throttle, in the attached can see a 3rd and 4th gear pull but can even perform great through 3 and 4 gears of WOT but still once off throttle and getting back on it will see pressure drop.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
