321rwhp @20psi. 4psi more boost has got me 30hp less than my previous tune.
No symptoms this time. Tuner double checked my cam timing, said I got it spot on. He even tried playing with the exhaust cam gear, but best results were where I had it. Set base ignition timing before it went on the dyno. IAT's are fine, not getting hot. It had no problems taking boost, it wasn't misfiring, it had plenty of fuel. It just doesn't make power. And I'm stumped.
Do you have a dyno plot for this? With AFR etc?
For reference.
Your making ALOT less power throughout the whole rev range than me.
To me that would rule out the turbo and point to a engine issue?
Edit: Actually looks like power is the same until my turbo kicks in at around 3500, then im always above you, which makes no sense ( pretty much same turbo, yours is bigger )
Edited by jay-rod
Haha totally happy to share, Mat (34GeeTeeTee) gave me your email address, I could email you some stuff if you prefer?
I did nothing :ph34r:
Here's the dyno sheet:
*snip*
Man this totally reminds me of my old ca18 180sx in 2004.
I had a friend with a ca 180 who was making tons more power than mine mod-for-mod. The more money I spent went nowhere/backwards. Everyone said "his was a freak and mine was more like the normal crappy CA's that can't make power", "should have bought an r32 or an sr20 powered car blah blah blah". I raged, I got upset, I threw money at it trying, late nights, everything we could think of to get it to make numbers and it just refused. As soon as boost came on there was a surge of power and then nothing up top. It felt fast for half a second then just made noise.
Eventually I had the car on for a final retune because it was up for sale, I couldn't stand it any more, I was fed up. Then, by complete accident the tuner found intake manifold butterflies that were possibly an optional factory extra (don't know for sure), but were always partially closed hence limiting all airflow and power. The tuner tied them open with a 10c cable tie.
After that, the thing ripped. Made something like 120hp extra than pre-ziptie :laugh: , even made more power than my friend's. After that it was all worth it.
TL;DR - don't give up. You have an rb25 neo. They make power.
This is starting to make me think that Hanaldo needs to go the whole hog and instrument the car fairly thoroughly before running it up on a dyno again. We'd want to see a boost gauge upstream the intercooler, after the intercooler but before the throttle and the obvious one in the plenum. We'd want a measurement of exhaust manifold pressure. We'd want (if anyone could be bothered) fuel flow meters installed before and after the rail. A tacho on the turbo would be nice too. Exhaust pyrometers....at least one, preferably 6.
Then we see what all that looks like. Then maybe we understand what is going on.
My VNT turbine system is alike the one in the video, I've watched it over a 100s of times before this.
I'm concerned about the affects of those nozzles at high boost, perhaps some thing making 400rwkws at 24psi. The EGT will rise dramatically with all those nozzles on the way. The nozzles them selves would be red hot that might snap or sieze after repetitive extreme theorem expansion and contraction.
This prototype is similar in a way of how it affects the shaft speed, but also constructed in a way that there are fewer moving parts standing in the way of gas passage.
The turbocharger is now installed, knowing the timing map would be very different, I'm backing off throttle around 5psi. There is a very noticeable differences in response compare to a normal SS2. Its getting tuned tomorrow. No guarantee it will work 100% according to plan, but at least it is a start.
Any update on this end up getting a tune ?
Unfortunately egt will always be the limiting factor for this style thing... and it's one thing you can't control. So the only way you could sell them is without warranty on the hotside?? if it looks promising I'd buy one without warranty. Same or better response and 240/50rwkw.
Here it is. Managed 384rwkws on 22psi. 20psi just before 3500RPMS. :woot:
Yellow and blue is VNT SS2, Green is standard from few weeks ago.
Notice the differences in response :D
Testing was pretty smooth in general, Its crazy to drive. I will post up other runs with captions later on.
Very interesting crazy response I guess hardest thing will be finding how reliable it'll be.when driving it does it hit hard with wheel spin or pretty liniear
Yes The only thing I didn't thought was if the actuator bracket would fit on my manifold. and it turned out I had no room so it was temporary attached to the timing belt case. We spent lots of time trying fix it solid there so it won't move. and it worked. I will need to make a proper bracket that attaches it to the turbocharger. But the whole ideology worked :woot: , This project took almost a year from drawing to manufacturing and testing. I'm very happy about it. That is a big step forward, I really want to see what it can make now with the 431rwkws ATR45 turbocharger.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
