Little update nothing extraordinary.
This is the first dyno result sent in by DvsJez (Great tuner) running our latest SS2 with 74mm compressor on a Auto r33. The turbo is built as a factory replacement unit internally gated.
One of the goal in the latest development was aerodynamic efficiency at reasonable shaft speed, which helps with boost control in higher rpm range, and I mentioned earlier that it required very little wastegate duty to stabilize boost.
This is running just off a 18psi waste gate pressure (normally holds 14psi on G3 and older version) with usual preload. notice there is no tapering off behavior.
its an excellent curve.
  • Like 1
Its just a normal SS2 with bush center. VNT model's power curve will be more linear. I'm building a prototype for it to be internally gated at this stage and confident it will bereliably.
The new series of wheels are aimed at lower shaft speed efficiency. Most of my customers use them on stock engines running up to 20psi. So the aim is to produce as much flow's possible based on same shaft speed.
Comparing current SS2 results with earlier G3, its made the same amount of power on 20psi then the G3 at 24psi, if discard peek power, the G3 had better power to boost ratio after 20psi.
How ever the SS2 had better power to boost ration before 20psi. No point making a turbo producing the same amount of power at higher boost level then some thing else that can do it at lower boost level.
I can always make some thing capable of running 30psi, just ask when ordering the turbocharger. ;)
Are you able to do the TD06 with 6cm housings and internal gate? T25 flange? Just bought the forged bottom end for my Z32 and i'm not 100% decided on turbos.
I've had a 300zx to play with and any thing large is horribly laggy.
Running L2 turbine in 6cm will act like a low comp NA most of the time.
I did a lot of work for the Z shop and pretty good with Lindsay. The high flowed manual turbos works out better then the TD04s that he had in both response and power.
I can high flow your stock turbo with FNT modification and SS1 billet wheel. That should be plenty for 300rwkws+ with excellent driveability.
I'm building it to run consistent 10 second passes so after 450+rwkw.
If you wish to try it I can certainly build two billet the SL20.5 in 6cm turbine. I'm sure its going to be very laggy.
alternatively you can run two SS1PU in .64 rear. They will be more responsive option for that goal.
Video sent in from Toshi (Another Great tuner). This is a Video clip from Laurel with a Rb25det engine that we high flowed its turbocharger few month back.
Awesome work Stao! Another track car proving the reliability of your awesomeness, and this one a pro drifter!
Can't beat a reputation like that!
Nice work stao. Just another happy customer from your epic turbochargers.
Id like to go for a hta 3076r stao. But I've been thinking over the weekend that I'd prefer to support a local aussie turbo builder. What would you suggest that would be the closest match from your turbocharger selection? So something capable of 375+kw atw's with good response. Obviously on e85. Would prefer a bb turbo but it's not a must. Let me know what you think.
Cheers Josh.
Cheers Josh.
Woah 375kw+ from a 3076? even on E85 I don't think I have seen any figures like that yet. Stao will definitely have a good match for you.
It's funny back in the day I always wanted ball bearing but now days I see that there is too little benefit from going ball bearing when bush bearing is generally much more reliable over the long term
If Money is not too much of a issue (still works out cheaper then the fp unit) I would highly recommend the VNT SS3 unit for some thing in this range. Just waiting for Trent to get back and I will pass on some results from it.
Yeah 375+kw from an HTA GT3076R - check out the back to back of a normal GT3076R to the ForcedPerformance HTA done by 34GeeTeeTee in this thread: http://www.skylinesaustralia.com/forums/topic/426059-forced-performance-hta-turbos/ - better than the GT3076R in every way, basically the ultimate RB25 turbo upgrade at this stage
Bush bearing isn't more reliable, just much cheaper to rebuild when they do fail.
Honestly none of that can match VNT models in terms of response and I can run a +2mm comp wheel to match the peek power easily. Specially when the car has cams and cam gears enhancing outcome.
I will post up results from the SS3 VNT once Trent gets back.
By understanding how both bearing setup works, I believe the bush bearing setup is more reliable, specially mine has been redeveloped. And I haven't had issues using them.
Thanks stao. Well after looking at results when they come through it may be the hypergear turbo for me. ;)
Can you pm me the price or write it up in the thread. Also as I said bb I prefer but not a absolute must.
Thanks Josh
I would hope VNT should give an advantage, it definitely looks like the VNT has an edge on spool- personally I am treating what you are doing there as R&D, I like it for sure but until decent track/drag/street kms have been done on them really it should be considered to be testing. If it turns out to be reliable, what kind of pricing would you be looking at? And would you retrofit the tech to any turbo? I can only imagine how epic a VNT HTA3582 would be on an RB25!
The new one has inverted nozzle arrangement, they are no longer fighting against exhaust flow. It will reduce the required actuation strength to minimum. This technology can be integrated to any turbine housings. I was thinking about doing few for GTRs. That way theycan run two big twins, making huge power responsively.
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
