I've modified that rear housing alittle since tuner mentioned it was too hot. Should have more chance of hitting 300rwkws now with a larger turbine housing. Just depending on how hard he wants to push the car.
just got a call...
car went 340hubber hp (253kw) on 1.5bar (no dyno correction)
standard rb20det
gtr injectors
z32 afm
atr43g3 0.63 on standard manifold
will get a graph up tomorrow
Edited by Cerbera
I need my brain looked at, we were looking at the graphs trying to work out why the car had a wierd curve (laggy and not making enough top end power)
Worked out I had f**ked setting the cam gears, will get them set again (they are 4deg out on inlet and 8 out exhaust) and hopefully retuned later in the week
Stao, he didn't need to... Was holding boost at pretty much any level through out the revs. Hoping for at least 30odd hp with the cam gears fixed and a whole lot more response. Can't believe i made such a stupid error haha
Edited by Cerbera
Some updates. I've made a new type custom turbine wheel aimed for power incensement with OEM turbine housings. Its expected to gain HP by roughly 10%。 Let me know if you are interested to try them out. I will pay for your tune at Dr.drift. You must have a fully working car with all supporting mods including ECU, injectors, Z32 AFM, 3inch turbo back exhaust and a metal intake pipe.
Also I want to make a note for people who's currently running this type of split dump pipes:
First of all the divider isolates the internal gate area which the gate flap does not open to a full 90 degrees. This result boost creep issues.
Diagram not up to scale, just give you a basic idea of what happens.
2ndly the inner diameter is 2.3 inches with the split pipe plumbed back. Factory dump has 2.5 inches inner diameter. In another word factory dump would flow better then above, it will create exhaust flow restrictions resulting high back pressure and high exhaust manifold temperture affecting overall power output. For the best results please run a 3inch turbo back pipe or a bell mouth dump with 3inch front pipe.
Tthe divider isolates the internal gate area which the gate flap does not open to a full 90 degrees. This result boost creep issues.
2ndly the inner diameter is 2.3 inches with the split pipe plumbed back. Factory dump has 2.5 inches inner diameter. In another word factory dump would flow better then above, it will create exhaust flow restriction, Please do run a 3inch turbo back pipe or a bell mouth dump with 3inch front pipe for high performance applications.
What you have posted above is totally incorrect. That product works fine, there is no exhaust restriction in the way you describe at all.
Also as the wastegate gases have been split off, the WG pipe does not need to be as big as the dump pipe.
As you can see from here:
The Skyline turbo wastegate flapper does not open the way you have shown in your diagram at all. (R33 & R34 are identical)
The flapper opes to a perpendicular end, rather than a parrallel one as your little diagram has shown...
As a turbo retailer... I'm shocked. :)
Edited by GTR_RB26TT
That was just a basic diagram so every one can understand what happens in there. Diagram is not upto scale.
A 2.3inch pipe does not flow any better then a 2.5 or 3 inch pipe. Simple as that.
Does not matter what it is, fact is the diagram couldn't be more wrong if you tried.
What you are saying occurs, and what actually occurs are two different things unfortunately and misleading/incorrect.
The wastegate flapper is not impeaded at all, that is cold hard fact.
Users are being mislead by that diagram - you should delete it.
I'm not going to argue with the interpretation. This issue have been arose before, This diagrams explain the very nature of the problem.
Of course you not - it cannot be argued and hence you have now removed the inaccurate information that should never have been posted in the first place.
The diagram you removed had zero impact on the situation, you would not have removed it if it were correct :D
The diagram you removed had zero impact on the situation, you would not have removed it if it were correct :thumbsup:
Stao has a hell of a lot of cred around here and is very generous with his knowledge and time helping people on these forums. He is also an expert on turbo's with valid point and you are just an annoying, rude NOBODY. :D
I rarely post, however I do read a lot and have been playing with turbos for 10 years myself.
The diagram I was questioing has now been removed, so sadly, you do not even know what you are commenting on.
I am not for one second saying Hypergear does not know what is going on.
However at times some of the information provided is just straight up incorrect & wrong.
Something you would not expect from such an expert, last nights diagram was another prime example of this.
If you saw what was posted last night, you would have your heads in your hands as I did last night viewing it.
Although I'm not sure what specifics you two are arguing about, Stao is correct about those split dumps jamming the wastegate. I had one of those split dumps on my car and it actually ruined my actuator diaphragm, dangerously gave me unlimited boost too. I disconnected actuator and moved the wastegate flap by hand...it only had 45 degrees of movement and kept getting stuck on something, which I thought was the pipe divider/seperator. Removed that and it was still getting stuck...turns out the wastegate pipe wasn't lining up properly and wasn't big enough. I die grinded the shit out of it, short of breaching the welds that hold the pipe onto the flange...and only then did it open up to 80 degrees. This STILL gave me boost creep (I run standard 7psi boost). I ditched it and got a custom 3 inch bellmouth made up, never had a boost creep / overboosting problem again.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
