Thats odd..
Have you checked cam timing on that motor Darren? just to make sure everything lines up to the marks that its supposed to?
Was the converter locked? If so, I can't see the box losing that much power between runs.
When I get mine tuned it is very consistent, although on other dyno's it has shown the same power loss each run. Either the front wasn't strapped down well enough (which is usually the cause) Or they simply weren't letting it cool enough between runs perhaps? I assume you have a large trans cooler?
I bet it hauls now, it doesn't feel brutal but it will be deceptively quick for such a heavy car.
Never ever looked at cams, its all stock with the cambelt done in japan not long ago. im suprised it took no more boost, but theres a few things i can look at
I'm not stressed about that, it was the power going or weirdo that had me stumped..weird.
the worst part is it is a family car i can't really play with it will nilly, or take the driveshaft out every week to dyno it, thats the pain in the ass,,lol
cheers
darren
converter locked, not letting cool down really, 2 massive transcoolers, one has a thermo, total overkill..lol
yeh its fast,it would be deceptively quick but even my mates vl that runs 10.3@133 doesn't feel quick to me either, thats linear to in its delivery
my mates brother has a car that we use for a guidepost..R34 270rwkw on 17-18psi, 12.00@117mph. ill see how it goes against that, my mates 338rwkw stagea flogs it
cheers
darren
I need to get my car looked at, its pinging at the end of the rev table around 6500 - 7000rpm. Its on actuator pressure to, about 14 - 15.5 psi. Has me stumped. I can't check what part of the ignition table it pings at because it doesn't always do it. I guesstimate between the 6400 rpm to 7000 rpm @ 6500 - 8678 load in the pfc. Sits on about 20 - 21 degrees in those rows. High boost is brutal power but I can't risk ever using it incase the pinging becomes dangerous. Really need to get my tune redone :( but before this I need to decide if my ECU is gonna change or not. Power FC to Adaptronic Select? Still want to unleash the potential 300kw the ss2 has.
I think its not a bad result for a auto considering its usually 20kws behind a manual box. What does a locked convert do? I'm thinking of working out my Kia's auto.
Pull a couple of degrees timing out of those cells.
If you manually lock the converter it locks the stator, similar to a manual clutch. The box will stall the engine if you come to a stop without disengaging it. Generally I run it always unlocked on the street, but on the dyno I lock it to transfer the power without as much loss or heat. It isn't a good idea to shift gears with the converter locked as you may snap the input shaft or damage the converter.
Generally the converter only locks on cruise for efficiency but the Stagea locks constantly in manual mode to improve acceleration, only unlocking to shift gears.
I pulled about 3 to 4 degrees out of everything above 5krpm mid to high load, I thought I creased it out as it didn't ping for about a week but today it reared its head again. I'll upload a dump of the original tune here so you can glance over it.
THat 6750 load line has a strangely high set of timings relative to the load lines above and below. A hump in the map if you will. The lower rpm end of that range you highlighted is prime pinging territory (upper end of the peak torque region). Makes you wonder if perhaps that part of the tune isn't a bit close to the edge.
Do you know if your fuel pressure is still up to scratch? Sudden onset pinging could be a weakening of the pump.
Yeah it does look abit weird hence why I went to jez to touch it up and thats the best we could do in a short time. You should see the previous tune which cost me too much.
Fuel pressure im not sure of. Its got a 1 year old 040 in there running off standard regulator. It does look high especially for 19 psi high boost. Thats why I was interested to see this guy running high timing with no issues.
If you notice after row 17 the timing drops off hard, I dropped the timing heaps just incase of the turbo over boosting for whatever reason
note: this is for a HKS2535 dinosaur turbo.. but it should give you an idea of how a timing map should look like.. ideally more load, less timing, less load more timing, and more timing after max torque vs. RPM.
powerFC Igntion.xls
Sound familiar Sarge, I was having similar issues with my hks pro s in my 33 random pinging that would come and go. Made it really hard to explain it to JEZ cause I would try and replicate it for him then it wouldn't ping. Poor bugger chucked it on the dyno, had a play, all good. 3 days later it would ping randomly again.
Ended up driving around for months on low boost cause I just didn't trust the knock sensors any more.
The WMI has definately gotten rid of any knock, but took a lot of stuffing around by Jez to sort out.
Does your head in aye!
Happened to u with another tuner too. Bloody cars :)
Yeah well lets not go into what you found when you had a look at the map lol.
As I said to you mate, it's ALWAYS the tuners fault lol
Sarge can u hear it pinging? Does it happen on high boost?
What are the afr's doing?
maybe not enough throttle enrichment? I had that issue when I smashed the pedal here and there, I added in more throttle enrichment and it went away (just from my personal experience)
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
