Stao can you make a VNT housing for the SS1PU? SR20 bolt on spec?
Internal or external gate? I will be happy to retune before I start tracking the car and can test it fully.
I'm building one now for the R33. Probably be ready by the end of next week then just have to wait for Trent to come back from UK again for tuning. But if that works out well then the same concept can be used in all T2x turbine housings.
Been driving the VNT SS3 every day for almost weeks now. Unlike other turbos at certain rev ranges stepping the paddle on the floor result in a blank spot. The SS3 VNT has no blank spots, G force comes in straight way with a touch of acceleration.
It doesn't have a "hard forced in seat pull" feel after 4500rpms like most turbos do in this range, it has a very smooth acceleration sensation, that pulls harder and harder from the start revving towards limiter. Also because the smoothness in acceleration there isn't a sudden peak of torque, which helped those tyres to grip a lot better. It makes a very fast car and should definitely pull some serious lap times on tracks.
Might get Sxxricho into sponsor ship with this turbocharger, Pretty sure he will break his previous records with it.
:3some:
High-mount, ex gate here I come.
Dude if this thing can survive Richo's punishment then a VNT can totally handle pootling around town with me as a road car...  :)
Agreed largely, though carbon buildup over time is one of the big issues VNT systems often have
Do you think carbon build up would be as much of a problem on E-Flex though Lithium? It seems to me now that it's not as much of an issue for my copper plugs, the same should be true for the entire system post-combustion. Have seen a few internet threads of engine tear downs (not failure related) of e85-fed cars which seemed remarkably "clean" compared to a petrol counterpart.
Probably not. At the end of the day the best way of knowing is Stao getting some of these things on cars and seeing how they perform in general, and over time - if they are an overall success then a win for everyone :)
There won't be any carbon build up there. Original VNT won't work in a high performance application, It is not a traditional VNT system, but based on its principle and has the same effects. I'm not worried about the reliability of this housing at all. But more interested in how to have them produced with better affordability. The aim to to retail them at around $1500.
Its interesting of how much water content E85 has. My exhaust manifold and turbine housing is always filled up with water when I remove them.
Photo of the high flowed Evo 10 turbocharger using reversed SLSS2 CHRA.
Yep, its because your car sits around a lot and the remnants of the fuel soak up moisture.
I am doubtful that the fuel itself is leaving water in the exhaust post burn, but its probably an indicator that the fuel system has the potential to suck up water. Danger danger!
My screamer etc is crusty and rusty and you can see water droplets in it (When plumbed back it drips from the join)
Nothing major and certainly nothing wrong with the fuel system ;)
No. No. The high water content in the exhaust is from fuel that burnt to produce water. There will be MUCH MUCH more water from that origin than there would be from absorbed water. The water vapour that sits in there when you shut it down is what is condensing out. The same thing happens with normal petrol, it's just that there is quite a lot more of it in the exhaust products of ethanol.
As I said in post above, but with actual numbers this time, the ratio of H2O to CO2 in petrol exhaust is 1.125:1. In ethanol exhaust that ratio increases to 1.5:1. It's a big jump. Makes the flue gas very "wet".
--edit-- corrected CO to CO2.
Edited by GTSBoy
  • Like 2
As I said in post above. but with actual numbers this time, the ratio of H2O to CO in petrol exhaust is 1.125:1. In ethanol exhaust that ratio increases to 1.5:1. It's a big jump. Makes the flue gas very "wet".
:3some:
You want to see the steam coming out my car's exhaust on these cold 2 degree mornings, it looks like a steam train, completely blocking my vision out the back window. I should get a pic for the lulz.
Stao, I would like you to keep one of those reverse rotation Evo wheels aside for me, do you want me to pay a deposit or something? I need to find an evo 8mr rear housing I think, as my standard evo 7 rear isn't the 10cm version as far as I know. Perhaps it could still be a good thing? Anyone know what the ar of the 7's is?
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
    • You can probably scrub the rust with a toothbrush or something. After you get the rust off flush well with water to neutralize and you will probably want to also use a fuel tank sealer to keep it from rusting again.
    • The sodium citrate solution is designed to buffer the citric acid to keep it from attacking metal quite so much, the guy that came up with that recipe did a ton of testing on how much metal loss occurs over time and it's nothing crazy unless you forget about it for months:
