I had the choice, I rebuilt my engine and chose not to port the head, or oversize the valves. I could have also gone with VQ35 cams but I would rather max the stock setup as I knew the turbo would be my limiting factor anyway.
Do you think the engine is more efficient now?
That was your choice and I respect that...
I personally would rather build a setup around the motor, not a motor around a stock set up...
Do I think the motor is more efficient now? No...
Am I positive it is more efficient now? Yes!
Then why was 8 degrees of timing required to be removed to stop the det? Why was the motor making less powerz at the same boost? Something aint kosher...
Did you double check the cam timing?
Less power?
I believe peak power figures were same, and what is power anyway?
Torque x rpm?
Why did the new motor create 30 more Newton meters of torque??
Cam timing is not the issue!
If you cant get those exhaust gases out quick enough, it is eventually going to reverse flow back to the valve, those gases carry extensive heat, especially in the first stage of the burn process... more then enough heat to act as an ignition sorce for the fresh air/fuel trying to make its way into the bore...
This. Unless there's something you've missed telling us, Scotty's got a point.
A bigger rear will only exacerbate the lag issue though. I'm not trying to shit on the engine build, quite the opposite, but I have completely different ideas on extracting usable power and torque from engines. I guess you are trying to get around the one limitation you refuse to discuss, fuel quality...
Civic is a pos
Didn't even start his morning lol
I get what your saying that I'm a crap driver. Ain't no dispute in that :P
But I thought whilst the head is off I may as well do it. *insert doitphaggot.gif* so in the future I wouldn't have to do it again if I decided to chase a crap load of power for the lolz. Know what I mean jelly bean?
you're not a crap driver, they're just really good ones.....:rofl:
yeah i know exactly what you mean,Im trying to decide if i should pull the head off my toyota for the same reason.....if I leave it on my car will remain slow but my wallet will remain thick...if it comes off my car will get faster but my wallet will get thinner...its a balancing act..
But I already said I didn't want to go E85 :/
I'm sure pump 98 fuel is not the limiting factor at the moment, plenty of people are making more power on 98 Octane
im not sure it will exacerbate (< i had to google this word ) the issue...would allow more free flowing exhaust...which might be all it needs...with the gases flowing so fast its going to spool up damn fast anyway it just needs to be able to vent it...I'd be looking at a highflowing billet comp wheel of some description though and EG a big one
Yeah I think we need to all remember here,
Trent was the guy tuning the car and will all the data and came to the conclusion that the turbo is a limiting factor
Plotting the engine on a GT3076 compressor map also confirms this
In saying that I will be trying to book in a dyno run sometime soon to run it without the cat back exhaust, airbox/panel filter, check the cooler system to see if there is somesort of restriction elsewhere
I'm sure once I stick a bigger turbo we will get results and then we can have a tea party and all eat scones and butterscotch finger biscuits
I get and respect that scotty, dont think im trying to put you down or get you upset!
I do believe a larger housing will have a minor effect of the lag, but I wouldn't class it as a lag "issue"
Its a circuit car, get it to boost and keep it there!
Are you saying fuel quality could be an issue? :/
Can I have scones too?
Tony gtx3076. External gate, 3.5" exhaust, cut a nice hole in the airbox.
Trust me, it'll be fun.
If you aren't making 320+kw buy a new car you rich accountant
f**k you Vic guys :( I wanna come to the tea party too, damn it.
Pick me up on the way past!
I'll bring the whipped cream
Us Vic guys even bring out the Cadbury favorites at these functions
I'll do this when you get rid of the Merc and get back into Jap cars :P
I think this is the bit of when people don't understand. By looking at a compressor map it only shown the capability of half a turbocharger, the exhaust side is not known. In this turbo system the maximum capacity of the turbocharger is reached when one out of the two ends reaches its capacity.
We can have a selection of turbine wheels and housings to run in combination with a single compressor wheel depending on the application and ends up with a variety of results. This is also the reason that I prefer hand on experience, as the end dyno reading is an more accurate prediction.
By looking at this result it sown that the compressor efficiency is not reached, how ever the turbine side is. By installing a larger compressor wheel based on the compressor map will only make the matter worse. matter fact of been a -12 degrees timing instead of the -8.
If external gate and E85 is not an option, then it will need a much larger exhaust wheel or housing, compressor end doesn't necessarily needs to be replaced. How ever by doing so it would affect response in a noticeable degree. Since the car still use factory drain trans, for road use and city driving, it won't be too comfortable.
Whilst I agree with you Stao, if you make the assumption that the turbo is well matched (and you'd be the one to tell us how well matched the front and rear of this particular turbo is, given that we're talking about an SS2, not a 3076 here), then if you plot your operating point off the top end of the compressor map then you'd have to think that you were also pushing the turbine side too hard.
The real question here is whether that operating point on the 3076 map is equally as bad on the SS2 compressor.. Actually, it's not. I still agree with you. The real question is whether the SS2's turbine side is too small, but I thought I'd point out that we're looking at an orange map when we're talking about an apple compressor.
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
