:rofl:
f*kn lolwat????
. Since the car still use factory drain trans, for road use and city driving, it won't be too comfortable.
i reckon it'll be alright ...maybe not ideal but good enough... mines a little doughy around town but its all worth it when sink the boot into it :D
Whilst I agree with you Stao, if you make the assumption that the turbo is well matched (and you'd be the one to tell us how well matched the front and rear of this particular turbo is, given that we're talking about an SS2, not a 3076 here), then if you plot your operating point off the top end of the compressor map then you'd have to think that you were also pushing the turbine side too hard.
The real question here is whether that operating point on the 3076 map is equally as bad on the SS2 compressor.. Actually, it's not. I still agree with you. The real question is whether the SS2's turbine side is too small, but I thought I'd point out that we're looking at an orange map when we're talking about an apple compressor.
Fair point GTSboy
Would have been ideal to use a ss2 compressor map and I actually asked for the ss2 compressor map, but as there wasn't one Stao said to use the Gt3076 compressor map
You're a compressed apple.
Haha :w00t:
  • Like 1
Well, if using the 3076 comp map was Stao's idea then obviously he reckons the SS2 compressor will have at least a broadly similar map. Doesn't say anything about the turbine side, but that's life.
And that actually brings up an interesting point. To create a compressor map for a given wheel is a lot of work. There is a metric shit-ton of information in a compressor map. You have to run the compressor at a particular shaft speed and vary the restriction on the compressor outlet whilst measuring the flow going through it very accurately, measure the temperature change of the air and the shaft speed, then do some calculations on some of that data to get the efficiency, just so you can plot a single point on the map. You have to do a whole lot of this at different shaft speeds and restrictions to flesh out the map, then joint your dots up in the appropriate lines and "circles" to create the map. This is within the means of your Garretts and your Borg Warners, but it is probably outside the means of nearly every smaller turbo manufacturer. Just doing it for one compressor is a lot of work, but if you've got 10 or 15 compressors on your catalogue, setting out to map them all would be a daunting task.
A 90T 60mm GT30 turbine is a reasonable comparison.
Us Vic guys even bring out the Cadbury favorites at these functions
I'll do this when you get rid of the Merc and get back into Jap cars :P
That's not gonna happen anytime soon
......Ummmm, cant say I totally aggree with you there hypergear....
A compressor map is made up of the efficiency islands based on a range of factors... one being shaft speed!
As whilst I agree its probably not the most accurate way to tell, it is very evident that blah_blahs engine has already gone over the maximum "efficient" shaft speed of 145,000rpm...
What causes the shaft to rotate? The turbine wheel!
Another interesting fact I learnt today talking to the right people:
An inefficient engine will run a higher timing advance to allow the extra time required to burn the a/f....
The more efficient the engine the less timing it will require with no power loss...
Are you talking about flow or volume?
Volume can be measured the same way a chamber is checked...
But once you've been doing this for over 10years you start to get the hang of it...
Where as many people thrive to get perfect port volumes, the fact of the matter is there is a lot more other important things to consider, as a few cc difference in a port is not going to tarnish a whole engines performance.
Im an odd type of guy...
Many years ago, back when we used flow benches, we were building a race engine, target power was just over 600hp....
Selected aftermarket heads for it, to which we copped a lot of criticism for as "they won't be big enough"
Done our port work to it, and got them flowed...
People litrally laughed at the results and mocked us...
Went ahead and bolted the heads on, and sent it to the engine dyno...
650hp...
So why would I choose to use a flow bench again?
So that was one engine....how do you know you havent gone backwards with others, or if the port is really noisy and turbulent
I dont really care for flow bench results, was just intrested to see what your RB results were
so dont take what im saying as critisism merely intrested
Why? So you can see how close you are to making the flow strip off the short turn. Or how about using a velocity probe to make sure you've got the cross sections right? Or see how well the flow is balanced around the periphery of the valve? Or seeing if the changes you make work better at low lift than high (or vice versa), or if you need to consider a different valve seat shape? etc etc etc.
Edited by GTSBoy
bit off topic but I read an interesting way to make a home flow bench using an afm and a vacumn the other day...
I'm sure you can figure the rest out but I thought it was rather clever...
Let me ask this...
Do you even know what your talking about?
The fact that you are using big technical words only tells me you have no idea what you are talking about so you are just trying to confuse everyone...
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
