That one is a bitch to change
Good luck
Thanks prob get some mates over so I don't have to do it all alone and to talk shit
Sorry to hear mate, Buy some gaskets and change anything suspect while your on the job :)
This will be the go if I'm changing that may as well fix the lot
G2.5 is a smaller turbo then a G3, they generally maxing out towards 260rwkws mark. So its about at its limit.
He's right, the graph shown is for a G3, but the intake leak might still be present and causing the 5ish psi boost drop. Fixing it might get him another 10-15kw from threshold to redline, definitely worth investigating.
http://www.hypergearturbos.com/atr43.html
The link says G3 but that is the graph from the G2.5 on the page. Either way I will suss out any leaks and give it another run soon.
That G2.5, I thought was a high flow. Preload the actuator about 10mms, if it starts to pin then its usually a restriction some where. This one don't have much of boost drop.
also stao,
your new website isn't meta tag searchable/ google submitted as i cant seem to find the new one on google which is meant to have more details on your range then the old website
Hiflow of a stock 25 turbo? It has a 3 inch inlet so i don't think so
lol... does it fry tyres when you smash the pedal?
Yes it does, because the car is so big and front wheel drive, it wheel spins on the spot with stock tires. lol
Preload the actuator to about 10mms. If you a have a boost gauge, check the pressure drop before and after the cooler, also try a run with no exhaust on.
Time for some M/T tyres? :P lol
This is for a good comparison of the new ATR28SS1 V ATR28G1 based on the Kia's G4GC engine:
SS1 at 8psi, G1 at 12psi:
ower:
Thin red: SS1 @ 8psi,
Green: G1 @ 12psi
Thick Red: NA none turbo @ 0psi
Boost:
Green is G1,
Yellow is SS1
SS1 at 14psi, G1 at 12psi:
ellow: SS1 @ 14psi
Green: G1 @ 12psi
Red: NA @ 0psi
Boost:
Yellow: SS1
Green: G1
This is an excellent turbo for around the 200rwkws on a SR20det.
I don't think that would be a problem. I can upgrade it to the latest profile, which is targeted at boost dropping issue with internal gate. PM if interested to go ahead.
Those are a set of CT20 Toyota Supra turbochargers that I've recently done. Those are rated to about 400HP each. Running ATR28G3 CHRAs. photos shown compressor and turbine wheel comparison, profiled compressor and turbine housings, and completed turbocharger assembly.
    • As strange as this sounds (as they are fixed back), my Bride Xero CS seats are the most comfortable seats I've used.  I vote go genuine.  The only downside I've found is on very long drives, you can't reposition your body while driving. So even though its comfy, being locked in the same position eventually becomes uncomfortable. I find myself stopping every 3 or so hours to stretch my legs on long drives.
    • You don't have to be bored driving a Camry. Not based on the way that a couple of f**king Ubereats/Didi/othersortofmethaddlednightshiftattheservicestationrecentimmmigrants were piloting them on the way to work this morning. f**k me dead!
    • FWIW, the Bride reps are really nice to sit in. The only complaint I have, other than the tear in my bolster, is that the velcro used to hold the backrest cushion in place, up under the headrest, is a little obvious and intrusive and could probably be done better. I don't know if that is a "feature" on the genuine ones also though. I haven't looked at a genuine one like the ones I have, only some of the older models. The other thing is, even though I bought the CF ones, I think the CF is really just decorative, over the top of the same FG as the normal seats. And so they really aren't light. Between the solidly built CF/FG seat, the steel frame in the recliner mechanism, and the solid-arse seat rail, they are probably heavier than even the stock seat. They are a serious lift to get in and out of the car.
    • Yes, and so the barest minimum power target is the one that makes the most sense. Massive power is fun, but you can only use it for 1.5s at a time, and only every now and then. Medium power levels allow you to enjoy the car far more often and for longer. 500 engine HP is just below 300 rwkW which is about the maximum that is sensible for any street car really. And for a 2.6L six, it will still leave you with a decent boost response and some sort of linearity of power delivery. As you get up towards 400rwkW the onset of power tends to be increasingly like a cliff and you need drag radials to keep the ground in proper contact with the car, and.... it's just not a car for driving around any more.
    • I already reached that conclusion myself after reading up a whole bunch and watching various videos from multiple sources. Don't know yet how I'd best manage that with the least amount of headache. Probably pulling the sump and just welding on a AN10 adapter or something. I also think it's healthy to take most opinions with a grain of salt, because experiences differ wildly and especially Aussies - when talking about RBs - don't know a world below 600whp drag builds. Personally I doubt I will ever take my R33 racing, so it's going to be a street car with the occasional spirited drive. Hence why I am (so far) under the impression that I'm going to be fine with a stock-ish engine for a while.
