  On 02/08/2013 at 5:41 AM, Manuel Kasko said:
That one is a bitch to change
Good luck
Thanks prob get some mates over so I don't have to do it all alone and to talk shit
  On 02/08/2013 at 6:11 AM, GTScotT said:
Sorry to hear mate, Buy some gaskets and change anything suspect while your on the job :)
This will be the go if I'm changing that may as well fix the lot
  On 02/08/2013 at 6:22 AM, hypergear said:
G2.5 is a smaller turbo then a G3, they generally maxing out towards 260rwkws mark. So its about at its limit.
  On 02/08/2013 at 6:33 AM, GTScotT said:
He's right, the graph shown is for a G3, but the intake leak might still be present and causing the 5ish psi boost drop. Fixing it might get him another 10-15kw from threshold to redline, definitely worth investigating.
http://www.hypergearturbos.com/atr43.html
The link says G3 but that is the graph from the G2.5 on the page. Either way I will suss out any leaks and give it another run soon.
That G2.5, I thought was a high flow. Preload the actuator about 10mms, if it starts to pin then its usually a restriction some where. This one don't have much of boost drop.
also stao,
your new website isn't meta tag searchable/ google submitted as i cant seem to find the new one on google which is meant to have more details on your range then the old website
Hiflow of a stock 25 turbo? It has a 3 inch inlet so i don't think so
  On 04/08/2013 at 10:38 PM, johnnilicte said:
lol... does it fry tyres when you smash the pedal?
Yes it does, because the car is so big and front wheel drive, it wheel spins on the spot with stock tires. lol
Preload the actuator to about 10mms. If you a have a boost gauge, check the pressure drop before and after the cooler, also try a run with no exhaust on.
Time for some M/T tyres? :P lol
This is for a good comparison of the new ATR28SS1 V ATR28G1 based on the Kia's G4GC engine:
SS1 at 8psi, G1 at 12psi:
ower:
Thin red: SS1 @ 8psi,
Green: G1 @ 12psi
Thick Red: NA none turbo @ 0psi
Boost:
Green is G1,
Yellow is SS1
SS1 at 14psi, G1 at 12psi:
ellow: SS1 @ 14psi
Green: G1 @ 12psi
Red: NA @ 0psi
Boost:
Yellow: SS1
Green: G1
This is an excellent turbo for around the 200rwkws on a SR20det.
I don't think that would be a problem. I can upgrade it to the latest profile, which is targeted at boost dropping issue with internal gate. PM if interested to go ahead.
Those are a set of CT20 Toyota Supra turbochargers that I've recently done. Those are rated to about 400HP each. Running ATR28G3 CHRAs. photos shown compressor and turbine wheel comparison, profiled compressor and turbine housings, and completed turbocharger assembly.
