You get full boost by 4300RPMs with RB25det using .82. It pulls lot harder.
If your purposes of buying this turbo is for mild power street use the .63 is fine, But it does get really hot under high boost if you use it for drifting or tracking.
Another small update:
Still remember this ATR43G3 unit with .82 turbine and .70 comp?
Got it dyno tuned today, car mad 298.5rwkws on 21psi with miss-fire. Only done 2 runs, car miss-fired very bad after, we changed plugs cleaned coils and nothing helped. I will give another try with splitfire coils in few weeks. I didn't grab the dynosheet this time. But dyno footage with 3 people in the boot is worth to look at:
(click on photo below to watch that video footage)
Also my engine comp shown:
130, 125, 125, 120, 125, 119
Next run will be with a new forged engine :miner:
nice power how much for the turbo? and what mods does it require to bolt up
Peak power was around 7000RPM. Check the 2nd run with people in the boot.
Power rise till red line, the curve is very similar to the 268rwkws run with restrictive intake and the 316rwkws run on with the sil180.
car was not strapped with wheel spin, Reved to 7000RPM as usual.
Next run will be with a new forged engine :)
These are the ones i wanna see more of :) 0.82 has a better power torque balance than 0.63.
I think this turbo is the same as my ATR28g4. Getting slightly better spool now with my alternator changed. Hitting 1 bar just after 4000rpm with no boost controller. 10psi Actuator with heap of preload
Further updates:
Apart from turbochargers our engineers are also dedicated in to engine building, how ever I'll not provide this service to the public. I will show every one how it’s done and costs involved. Any useful advise is welcomed.
Primary goal:
This engine will be used for our turbocharger evaluation pusposes, My goal is 350rwkws.
This engine will be built with stock cams using forged pistons only, so Power vs Boost generated from it would be identical to any other healthy standard RB25dets.
Engine:
96 model RB25det engine bought from local wrecker.
An hour later its in bits:
Cracked piston in cyc 6. But bore seems to be in ok condition
I’ll be using forged CP 20 thou over sized RB25det pistons with rings and pins. The piston set cost $1150 AUD.
Engine block's been sent away to Reflex engine services. Its going to cost $260 to re-bore all 6 cyc with block thermo bathed. Engine head cost $250 to trim and bath.
Also for people whom owns a pair of CT12a Powered 1JZ Soarers. We can high flow them to 2860rs Disco CHRA specifications in sleeve bearing:
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
