I cant get VCT working unless I buy a VCT intake cam and a new VCT solenoid and gear. I have previously had too much hassle with getting VCT to work in my SR so I threw it away and put non VCT cams in my car.
I am very happy with the delivery as it is anyway. Going to keep it as is and just want to go finish my tune.
Man there are a lot of people out there with your highflows who use their cars for PROPER motor sport duties. That is crazy :)
Cheap reliable turbo that can be rebuilt cheaply in AUS. Also cause he's always working on improving his products can't go wrong
Newly designed exhaust wheel finally out of the furnaces today. This particular one was from the 407rwkws SS3 prototype with a Dia of 66mm. Will be making the turbine shaft and friction weld them in the next few days. This wheel is also made to improve the exhaust side flow ability with current bolton ATR43 series turbochargers, without adding additional lag.
Looks good Stao :)
Took a few quick photos of my turbo today, first time I've had time to even look at it since it got back here.
Might get some better photos tomorrow but in the mean time heres some photos off my phone:
Happy with the way it looks, Can't wait t osee it on the car. I have no excuses now that the turbo is back to not get started on this engine
Thanks again Stao for making this happen :)
Edited by 89CAL
SS2
:ph34r:
Yeah was an SS2CB, one of Stao's original ones produced not long after the prototype (If memory serves me correctly?)
It's been too long since I actually got the turbo. Need to put motor in car and stop making excuses
Those are the current SS turbochargers, I'm particularly interested in the result of the SS1PU as the latest compressor has made a difference in stabilizing upper rev boost level as well as the turbo's response.
My test rig will be down graded using standard exhaust manifold and internal gate, based on the completion of the SS4 Alpha development. From there I will obtain further data based on the performance of our latest SS turbochargers internally gated, In which should archive a much better out come then what I've originally archived few years ago.
Lastly, internally gated SS Alpha turbochargers are under construction, means a new range of big power, responsive and easy fitment turbo options will soon be available for Rb25det engines.
Stao do you think there would be much benefit for me to change to your new profile? As noted I will be heading back to the dyno soon so I should make the most of it.
After some trailing and testing with using the G4 chra the housing type and profile bell shapes are pretty much set to optimum for a Rb25det engine. So far this is the most responsive 3582 equivalent turbocharger I've trailed. Obviously it will be a controlled run finding out what my cam behaviors are and gathering data for the SS4 alpha series to run against.
Trent and Cat just had their fun in China and now back to work. My dyno run is booked in for tomorrow, and hopefully things will run smoothly.
Here's controlled run from today. The maximum power reached was 445rwkws with 25psi @ 4500RPMs.
Boost level comparison result from previous run using the same turbocharger.
No, its not responsive for a daily, how ever not bad considering the peek power it managed. This is our base run using standard cast compressor wheel, my billet wheel versions will be act against the result above, and the desired out come would be for better power and response. 460rwkws with 25psi by 4300RPM would be a nice goal to reach
That graph looks mental straight up after 4000rpm
will be awesome to drive if it got traction
Goes from 100rwkw at 4000rpm to 325rwkw in a few hundred rpm
If these turbos could handle big boost 30psi+ you could be onto a winner for those after big power
decent response simalar to the precision turbo range
Should be well over 500rwkw at over 30psi if it can handle it but you would need the supporting mods to test it more fuel
Ho-lee-f*k! That's mental. I'd love to drive it on the street :) Licence would be gone in a second but the tyre smoke just beforehand would be epic.
That's pump fuel and low mount?
That power level would be very fast at the drags
You should try winding the boost up and test it out at the strip
Is that turbo still internal gate and single scroll?
Just re read it still cast comp wheel and no vnt yet
With a billet comp should be even better but I'm not sure about the vnt might choke it up top restricting power
But it's definately heading in the right direction
Edited by hy_rpm
This is running VNT, hence the difference in response. Thats on the high mount, external gate and e85. for some reason the boost curve appears laggier on paper then on road. I can see my boost gauge sitting at 15psi at 4000RPM 4th gear on the high way. Since its just a controlled test so never mind as long as the billet series works better.
If I can get rid of 300rpms of lag it would be sweet as for a daily.
Definitely very fast, I need to a 4WD system to put all of those on the road.
    • Oof, I don't think you should add it up like that! It sounds much better at $21 per issue. I don't see any problem there if you enjoy the process and the result. I really like the magazine side of it with all the little tidbits and facts. Also, if anything, these forums are all about spending unreasonable amounts of money on hobbys. I wouldn't call it a self-help group because people generally suggest to spend more
    • I put another 2 layers of putty and still getting pinholes. Think i might either try the filler first then putty or just leave the little specs of guidecoat as is and get primer to fill it in. I think i misread understood what you said above when you said my glazing putty wasnt enough for the size of the area. I thought you meant 1 coat and i needed to. But i think what you meant was that I needed filler first? I also went a bit too far out the repair area as my spreader is a bit large.
    • You do sorta. In my instance they were little specs and I didn't even think they'd be pin holes but it all makes sense now. Huge learnings there!
    • Ah ok that makes sense and it's where i think i went wrong because before when i put filler then putty, i didn't have this issue and now i do because i only put 1 coat of putty. Thanks for that heaps man, it's a good way to put it! With my putty I'm using the dolphin glaze which i just saw it says finishing putty lol. I didnt put filler cause it was a shallow area but i see what you're saying. Also I'm an idiot, i just realised that while i put new putty there are pinholes! I probably saw it before and ignored it for whatever reason. I think because i thought putty is used to fill pin holes that itself wont make pinholes but that's incorrect of course. I feel silly now haha. ok I think I know what to do next. Thanks man!
    • Yes correct, the guide coat is showing low spots, in this instance the low spots are pin holes. I agree wetting the areas makes it more visible (but you can see it's there before you wet it as well lol).  Once the panel is flat, the guide coat will be gone
