You are actually moving an engine from the wrecker in the trunk of a Skyline??
;):thumbsup:
ons only, so Power vs Boost generated from it would be identical to any other healthy standard RB25dets.
Engine:
96 model RB25det engine bought from local wrecker.
The compressor map with the standard high flow would be identical as:
http://www.turbobygarrett.com/turbobygarre...60-15comp_e.jpg
Since its running the same size wheel in same size housing.
Further updates:
The ARP bolts, Bearings and full Gasket set cost $691.
Engine come back horned and cleaned ($535). The job was abit rough thou, I spent hours buffing out the left over residuals from previous head gasket, Which I paid to get it cleaned. Any way:
Engine block with pistons back in and head assembled:
Well original goal of building this engine is not for that wow factor, I just need a very solid standard engine to evaluate max power out put on 98 fuel for all high flow profiles and bolton ATR43s. So Power vs Boost vs RPM would be identical with the same turbo on any standard RB25dets. This is also a None Neo motor, Neo engines would pickup better power and response.
Results with fully moded head, cams, and manifold would be deceptive as no one else has the same mod. But I will get them to run with race fuel and Nos after the evaluation for abit of fun :whistling: .
Link G4 Ecu
hiflowed turbo
550cc injectors
3" dump/exhaust gutted cat
intercooler
bosch 040 fuel pump
5puk exceedy clutch
and wind that up to 20psi and watch the figures climb haha
Hi Guys, I'v just bought a fully stock R33 of JSA 2 weeks ago. I'm looking to get me turbo high flowed and make some power. Can you give me a list of recommended mods? Cheers.
If its just been complianced there are few of things to be done:
1. Install a front mount cooler (we can supply).
2. Install a strong clutch (recommend Xtreme clutch kits at Ace Brakes ) if your is stock.
3. Install a full 3inch turbo back exhaust with a honeycomb cat. (JSA are Xforce dealers they should have plenty).
4. Get a set of 550cc / 700cc injectors (Try Cjmotors).
5. Get a Z32 AFM. Try Japart or see if JSA's got one.
6. Get a 3inch metal induction pipe made up (Try Glenroy exhaust) and get your self a good pod filter.
7. Get a PFC or Z32 ECU with Nistune chip (You can get that done at my recommended tuners).
8. Bring pass your stock turbo and have a chat, we have few different profiles and turbine housings to choice from.
9. With few hours of Dyno time at Dr.drift or Status your car would be pretty sweet to drive.
Another update:
This is a OP6 high flow that we did for a customer's R33 (none Neo engine) earlier using our updated turbine wheel. It made 241rwkws at 15psi full boost by 3450RPMs with 98 fuel. I'm pretty happy with it, Dyno sheet showing results of tuned maps before and after high flow. It made more power every where without more lag.
The other thing that I'm pleased with is the power curve which sits lot more gradual instead of linear. So the wheels will be able to convert lot more of those energy onto acceleration momentum.
Hi mate, am interested in a Hi Flow Turbo..
looking at running around 230rwkw..
How much does it cost to Hi-flow my current turbo I got a gT-t r34.
& do i take it to my mechanic for a straight bolt on?
I have a new front mount intercooler,
Clutch.
Do i need an ECU?
Whats the cheapest ECU I Can get?
The cost to high flow is $960 inc GST and braided oil feeding line. Every thing bolt back on. The cheapest ECU option would be getting a Nistune ECU installed and you need a set of at least 550cc injectors and a Z32 AFM. Will get you 230rwkws with 14psi of boost.
With The Nistune ECU you can order direct from Matt on: enquiries@nistune.com its $350 installed. Some of your local tuners can also install it as a package with the tune.
Also some update with my engine build:
The engine build has been complete and it is now back into the car. How ever it floods it self every time I crank. I guess I have to toll it to Sam to play with the map. Not having much luck with it this time.
Hi Stao,
i been thinking to Hiflow my turbo for a while now, just wondering once u guys Hiflow it do i need to upgrade my ECU straight away
or car i still drive on it till i get around to buy my new ecu
thanks
I would assume you shouldn't have any problems driving it around on low boost with standard ECU for a while.
Though having said that, it comes with a high pressure actuator, so you will have a lot of trouble driving it around without overboosting.
I will be receiving mine soon, and will need to drive it on stock ECU to the tuner after fitting. I'm not looking forward to that part lol.
I'd recommend (as I'm sure others will too) to just save up some more, and get it done at the same time as other necessary supporting mods (injectors, fuel pump and ECU)
Hi Stao,
thanks
Once turbo is high flowed you can still run about 10psi with stock ECU and 98 fuel. There will still be a very noticeable difference in power and torque. It is recommended to go for a aftermarket ecu some injectors and etc to get the full potential of your car.
Some updates from yesterday:
Engine's build has been completed.
Taking the old engine out with respect to its 6 month service.
New engine is dumped in, alone with a evaluation subject: OP6 high flow
How ever the engine fouls plug on crank. Tolled it to Dr.drift today and hopping for the best
Stao/anyone who may know:
I am intending on at the very least running this as my temp setup until I can get a hard intake setup made, will this flow 18psi through an ATR43G2 without causing restriction?
3" turbo inlet > 3" to 2.5" silicon adapter > standard R33 intake piping with 3" steel pipe mod to stop sucking closed > pod filter
the 2.5" silicon after the turbo is my concern, but I've heard that it won't cause an airflow problem as long as the intake piping doesn't suck itself closed.
Confirm/deny? Thanks :ermm:
Here are 3x dyno sheets for your reference as stock intake system, stock intake pipe with metal insert didn't work. I also believe your friend Pat experienced very difference result before and after upgrading to 3inch metal intake with pod. His comments are in page 39.
Results:
1. ATR43G2 Stock intake pipe with air box no filter. Intake pipe sucking shut.
2. ATR45 running stock intake pipe with metal sleeve stopping it from shutting with pod filter. (left)
ATR45 running 3inch metal intake pipe with pod filter. (right)
The sleeve insert run ended early as it not only restricting power, it did some thing strange (knocking?) and inconsistency in AFM reading. This run ended early.
So please use a 3 inch or better 4 inch intake pipe with a good flow pod filter. Or at least use that for tuning.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 馃槓
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
