Stao does that then mean the water lines etc will line up perfectly or will they be the same as my current SS1PU.
I had a huge headache with the r33 organising the oil return and the water lines when fitting it so I thought if I stuck with the stock setup for the R34 then I wouldn't have that issue again.
The SS1PU has the smaller bearing housing. So they are same the as earlier version.
G2/SS2 and larger versions runs the larger T3x bearing housing. Those are easier to install. Best to have a look at the installation walk through for both in page 1.
Can reuse factory compressor end, not the turbine end. Which gives it a factory look.
Birds. For the drags you will need some 275 MTs, run them at 18psi, and worm them up nicely. If the launch is perfect then a good time is more promising.
One thing I didn't like about Heathcote is how they washes rubber residuals at the start of runway with water every time a car lunches. So we always taking off on wet tires.
They do that at all drag strips, just go around it...
I can't fit 275s without some serious bubble; I only have 9 inch wheels and they come out quite wide to the guards already :(
Can anyone with an SS1PU and a Z32 AFM please check their peak AFM voltage on WOT (preferably 3rd of 4th gear) ??
Stao if you can ask Trent for this that would be great also.
Thanks,
I'm running the 275 on 9.5 inches wheels in 17 inches. You can get them to fit.
By the way, I've found a local company whom's happy to produce the braided oil lines at a much cheaper price. as well as the quantity that we are producing. I'm happy to deduce $100 off all High flow jobs as we as none special priced listed items.
Means your high flow job is now $860, and SS1PU/SS2 is $1350 all including oil lines.
Also we are a little over stocked with our billet SS2.5's parts. Now offering cheap for $850 each complete turbocharger with oil line.
C'mon Stao you're killing me, having bought a regular price SS2 just last week ;)
Great prices people, get on em!
Thanks,
No members with an SS1PU want to help out a member who does his best to help everyone he can? :(
I don't have a multimeter sorry mate
If you have a powerFC it will show on the handjob (hand commander), or it will show if you have the software for a nistune if thats what you run.
If anyone has access to either of the above with the same turbo please let me know what reading they are getting at WOT in higher gears :) peak reading.
Birds don't you run a PFC with your SS1PU?
Lol awesome, that's hilarious :)
Good luck for the weekend, will be interesting to see!
Yes indeed, in fact all the guys at tires joint were beating wither this is car has an intercooler or an oversized radiator. I just made 1 person $100 richer today, no one thought this is a turbocharged kia. Ended up with some 225 / 65 / 16 Nitto tires. Still wheel spinning and torque steer all over the places. MT don't make any tires in this size.
How ever this result might give a little indication of what the SS1.5 would do on a SR20det motor, knowing the .64 might be a little chockish, this is running a .86 FNT rear with a 66mm compressor. We were been able to add an additional 5 degrees of timing compare to what it was in the .64 rear. Because the additional timing down low and up top, we ended up picking up 40kws with out getting additional lag.
At about 20psi this turbo would be an idle turbocharger for a SR, with similar response to a Disco.
    • Thank you GTSBoy and MBS206 I have done the compression test with the motor out of the vehicle, reason for the test was to see if I needed to remove the head and do rings etc while its out. I'm in the process of respraying the vehicle and tidying up a few things. Story behind it all is I've just purchased the skyline and it was running when I got it, never drove it on the street though as I wanted to pull it down and do it all up again before registering it. the gentleman I purchased it from told me the motor has a forged bottom end and has a decent tune through it but I was going to pull the sump off anyway to see if it is a forged bottom end. that's why I thought id do a compression test beforehand.
    • Man, I'm kind of amazed that the price of the turbo has not changed in 7 years. Everything else is inflating beyond reason, but not this? Good on Tao / hypergear I guess? Anyways, good luck with the sale!
    • I'm selling my brand new, in the box, never used Hypergear ATR45 - and I had some additions I paid for a few yrs back when I purchased it. Never ended up having the rest of the money to add all the mods at once, so I just ended up slowly selling each part. I originally had it internally gated, with the dump pipe, however I found it was incompatible with what I was going to use it for, so I contacted (I think Ken) from Hypergear, and he and I messaged back and forth & he got me to ship the turbo back, where they modified it & made it externally gated, and gave me the 5 bolt dump pipe attachment for custom welding. (Photos below) This turbo like I said has never touched the inside of an engine bay, it's completely brand new, never used, been sitting in the same box it arrived in, covered in plastic & all. Below are the photos of it: And while the guys at Hypergear were making it in-shop, they sent me some photos of the process: I'm looking at selling this just because I'm in need of the money right now, and don't have plans on modifying the 34 anytime soon - and from reviews & peformance sheets, this turbo had amazing results back when I was researching. The turbo was purchased in 2018 for $1.9k, with the mods I got added on. Looking at the website now, for the same turbo they sell (ATR45SAT), with the current addons it adds up to $1830 for the turbo Current addons included: - Bolted dump adaptor - Ball bearing CHRA - Braided oil feeding line So I'm looking to possibly sell it for around $1800, with shipping included in that 1.8k, It cost me around $120 to ship - so yeah thought I'd throw it out there and see if anyone was interested in purchasing. Cheers!
    • Turn up your speakers https://youtu.be/5_GK5ChNjOs?feature=shared
