Thanks. a member here is designing a whole new website along with the logos at moment. Our website will be launched in few weeks time.
and here is some serious stuff. The 1200cc injectors are in, and we maxed out the SS4 Alpha turbocharger this morning at 490rwkws on 27psi of boost. We tried to add more boost in and ignition started to break down.
VCT does not make any differences I think I've bought the wrong set of cams.
Crazy standing next to it, the engine wants to torque its self free from the gear box, it tilted up at like 50mms out of the engine bay. I don't think my current hardware is capable of handling more safely.
Just come back from Trents. and a little update on our new R33 high flowed turbocharger. This is the result from current standard high flow profile priced at $860 inc oil feeding line.
Result take from SxxRicho's R33 skyline, stock engine, factory manifold internally gated on E85
Dumped 2 degrees of timing up top making it extra safe for tracks.
Thick red: 322rwkws, Thin red was 312rwkws, Green which is 294rwkws
Hey Tao I was just wondering which turbo this result was from?
I've got the standard R33 highflow (non-PU with 21U rear housing, standard comp housing machined out by you).
I made 241KW on 15psi (standard injectors)
I'm looking to change to E85 and put more boost (around 20psi or more if safe). Do you know how much power I can make?
Thanks
Edited by Blackkers
This is the current version I believe those where initiated from Jun 13th this year. And that is for all the recent high flows making decent numbers including few Toshi tuned.
I'm pretty happy with this profile, engineered similar to the new SS2s those are also made to handle and hold upper rev boost, and even thou in a tinny R33's turbine housing every thing worked out extremely well. That should put John in the lead now. Looking back compare to the older profile More power, more torque and much better boost control.
E85 usually adds 40kws on top of existing power figure. You should be able to get pretty close to 300rwkws with it on E85 with plenty of boost.
Planing to hit the strip in few weeks time. hopefully nothing breaks on the tracks.
Not sure if its true or not it appears the fastest R33 GTST with a 2.5L engine is from Nismo performance center. its sitting on 9.9sec / 140m/H with 900rwhp, running cross ply tires.
If 656rwhp can get me a low 11s in this car I will be pretty happy.
Nah the quickest GTS25T that I know of was marginally quicker and from the UK - ran 9.93 @ 140mph with the stock 5-speed gearbox back in 2006. Really frustrating that he swore he was going to push it to the next level, but then dumped an RB26 into it deciding (I guess it makes sense aside from the distinct fail of deciding an RB26 is the best of everything, hahaha) that he may as well go the best of everything. He did the 9.9 on 27psi, and had made 900whp on around 40psi - so it had the power to go much faster... he just never harnessed it :(
With 656rwhp you should be running ~135MPH tbh which is mid 10 sec territory.
Nice work stao..now buy some crossplys and slicks..lol
I like the new logo, i really think you should push the MADE IN AUSTRALIA angle pretty hard aswell, as when i mention the name hypergear,
people always think china turbo and then i have to explain or try to..
cheers
darren
Thats excellent work. Any results with a R34 turbo?
how did the 1200cc injectors go?
any issues with idle or tuning?
Shouldnt have any issues with that size :)
HOLY SHEET, you're alive! haha
I think I beat you in the smoke department at texi (however Y U NO GO?)
Yep i am alive! Been a busy month :)
Damn you, but if you did.... GOOD JOB :D
I had renovations to do, got 5-6 weeks to get a house on the market as i purchased another one!
  • Like 1
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
