stupid question.. maby... ( are there any epa problems with highflowing a stock turbo in standard housings? )
Technically you its not allowed but epa cant tell that you have hi flowed the inernals so its fine to pass a test with a hi flow.
Little update:
This is a cheap sleeve bearing rebuild option ($950 inc GST) for people with totally blown (need new core) GT3582 turbos.
what sort of power are you chasing for?
the G1 runs of a 71mm 52T comp and G2 runs off a 76mm 52T comp. For RB20 they are ok to run in .63 turbine housings.
Looking for about 220-230kw with minimal lag
Stao, i am really starting to think my turbo is causing all of my lag problems.
I have replaced all my rubber joiners, new intercooler, replaced other engine bay hoses, disconnected boost gauge and boost controller and the car is still a laggy peice of crap.
3psi by 3000rpm 10psi by around 4800rpm all done in 4th gear. I replace one last hose today and noticed the turbo side of the car is alot louder that the front or other side.
Car never had lag issue with stock turbo (Yes i know its a bigger turbo and will have more lag but not this much)
Just had a big day tuning at status. This is the first run with my new forged engine. Every thing on this engine apart from pistons are stock standard, so any good healthy RB25det will be able to do the same.
Just recap of modifications list:
800cc injectors
Nistune ECU
Z32 AFM
600x300x75mm FMIC
3inch turbo back exhaust
3inch intake pipe with pod.
CP pistons
ATR43G3 / Pu high flow .82
Stock engine head
Stock cams
Stock cam gears
Stock exhaust manifold
Stock inlet manifold
Stock fuel rail
Stock engine block, Con rod & Crank.
This is a controlled run based on BP 98 Fuel, No boost controller, No wastegate controller.
Car made peek of 303rwkws at 20psi with drop to 17psi (can be fixed with Gate controller). The constant was between 295 to 300rwkws.
    • Ha ha ha! I know those feels mate I've finally got the garage cleared enough that next weekend I'll do some actual work on my car (hopefully). Unfortunately garage isn't usable after 10am at the moment That said, I've done a lot of work this weekend on helping finalise a friend's Production Race car. Full started Christmas Eve. We're down to about 8 tasks on the list, including "get a wheel alignment". Sometimes it's just easier working on someone else's car or project than our own stuff 😛
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
    • hmmm that's not ideal. This is a pretty new engine right, will be interesting if your engine guy has any theories about causes
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
