Hi every one I'm back to business. The Kia project in China is completed but disappointed in the way of how it has been organized, some of you might already seen my update on Facebook.
Updating with some video footages from xxxRicho's R33 running the latest R33 turbo high flow with 294rwkws (E85) at
Motul ADVAN World Time Attack 2013 Club Sprint ending in 5th
Have any of you guys used the Kando oil/water line kit to fit up your SS1/SS2 turbos?
They state this is made for the stock turbo in the stock location.
Link:
http://www.ebay.com.au/itm/Turbo-Oil-Water-Line-Stock-T3-Nissan-Skyline-RB25DET-6AN-/271306380797?pt=AU_Car_Parts_Accessories&hash=item3f2b1ed5fd&_uhb=1
Used Kando lines on my low mount standard manifold IWG SS2. Fits perfectly.
sex, thanks Josh will order now :)
Stao was a little hesitant on saying if it fits (fair enough)
Am also using Kando lines with my SS1PU on my SR20.
I simply used the banjo Stao provided and screwed the -4AN kando line onto that. The rest work a treat!
  • Like 1
Yea true.
Some updates on the new SS1PU turbocharger prototype that is due for trailing very soon. So basically I still want the current SS1PU's response but with a lot more power. Well here it is:
What are the changes Stao?
I was thinking the turbine on your current highflow seems to be of made of stardust or something, and was wondering if that technology can be carried over the the SS1PU?
I flat out think a 2IU highflow on my SR would be crazy.. I'm so tempted to try.
The compressor is the newer gen 11 blade SS compressor I'm sure. They are all using that now.
But I notice Stao is actually using his T3 5 bolt rear housing, so that means the bearing case and turbine wheel are no longer the GT28 sized item.
Stao I am SERIOUSLY interested in this turbo... It may complement my T3 highmount setup I have lurking in the garage. Please share results ASAP!
Damn, you take a very impressive photo of a turbo haha..
Really considering getting a new turbo soon, as I am already sick of the t04e.. And think the seals are starting to leak a little.
Also not very good on the street, I know you said an sspu1.5 but that was a while back and maybe things have changed a little with the way there improved.
For an rb20det. I'm at 171kw and don't see and boost until about 4,400-4,600rmp.
Anything over 200kw and a little more responsive and I'll be stoked :)
Yellow jackets, Z32 afm & yellow jackets are also ready to go in when I have enough for a hypergear turbo + tune
This is a new turbine side design for a Rb25det it is different to whats in the standard high flows, I really want it to make more power with better response as if possible.
hy_rpm: I did make a 11 blade 60mm compressor wheel for the SR20det motors as well as a 64mm and a 68mm wheel. I believe the maximum that a SS1PU turbine can perform on a SR20det would be towards 250rwkws with cams on pump 98, so those are really targeting at the responsive end.
ZRBE: As for the RB20det my recommendation would be the 64mm billet SS1 turbocharger. it has similar response to a 2530 with abit more power.
  • Like 1
We will stick to the original plan and I'll be using e85 so high boost 25psi
You suggested to try a ss1.5 fnt .86ar due to high boost and s14 comp housing so will be bolt on and go from there
260-270rwkw should be achievable if the turbine is capable of 250rwkw on pump 98
As pump usually caps the boost to 20psi as more than that is pushing it due to pinging and heat but e85 allows me to run 5psi more boost which should net me 25kw we see
Thanks
Also that's what I was after similar power and response to the hks2530 as that was my last turbo setup on my sr20det and I was happy with that it made 250rwkw on 22psi dropping 19psi on eflex full boost by 3400rpm
I was happy and wouldn't have changed it but the bearings got noisy in it
So would I be better with the .64 or with struggle with 25psi as that's what the 2530 had
Depending on whats struggling. At that boost level it could be the compressor or the turbine, I think its more of the compressor end. I've pmed you with some recommendations if you would like to trail them out. I'll be happy modifying them free to reach your performance target.
+1 for the above - He really will.
Is that new thing suitable for, I dunno, some guy wanting to run a low mount smallish turbo at 28psi on a RB28 auto sedan? ;)
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
