Joshbigt62r Posted November 23, 2013 Share Posted November 23, 2013 Underlying problem some where there obviously. Did you drop the exhaust for a run to see if it was a restriction? Or a collapsed cat or something? Boost leek perhaps and so on. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/452/#findComment-7119581 Share on other sites More sharing options...
GTScotT Posted November 23, 2013 Share Posted November 23, 2013 Hmm well its not a BAD result, not at all.. 250kw all in between 3500-4000 is pretty good. It definitely tells me that the turbo is doing its thing and its doing it well.. If there is a 'problem' it is somewhere else on the setup. A 2.5 is probably good for 270 max, and there is no guarantee that a given motor combo can draw the max from a given turbo. Have you asked your tuner what could be causing it? I find its easier if you tell them it has a brand name turbo they tend to listen more and try harder when they think it has an expensive brand name on it, like Garrett or GReddy. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/452/#findComment-7119583 Share on other sites More sharing options...
Joshbigt62r Posted November 23, 2013 Share Posted November 23, 2013 Yeah you are definitely right Scotty 250kw all in by those revs is a very decent result. I must have been having a blonde moment lol because I have got no idea what I was thinking. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/452/#findComment-7119608 Share on other sites More sharing options...
GTScotT Posted November 23, 2013 Share Posted November 23, 2013 LOL yeah its a pretty tidy result, all good. I'd like to see the graph, if it hasn't already been posted. Will help work out what its doing. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/452/#findComment-7119630 Share on other sites More sharing options...
hypergear Posted November 23, 2013 Author Share Posted November 23, 2013 It is hard to determine, just like Garrett results on the dyno page are mixed. This particularly happens to turbos internal gate, factory manifold with simply bolt on setups. Turbo wise they all identical and pre-trailed. Yet results are mixed. Since I have a Skyline my self, I do spend time in finding issues that could cause specific problems, do best to rectify through altering the physical shape and housings of the turbochargers, and keep customers informed. Apart from the car it self and tune, some times the fuel it self also rise concerns. Some one in WA region mentioned a 70kws gain on E85 over pump 98, not only applying to one of ours but also a friends whom's using a 3076, final results between the two are minimum. That power difference in fuel some thing we could never get in Vic. Is it because the E85 fuel is extremely good in their region or is it the pump 98 fuel substandard. Generally, by keep the induction and exhaust free flow as possible, good cooler, good fuel, correct engine timing, and a tuner is knowledgeable. The results usually be parable with controlled. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/452/#findComment-7119656 Share on other sites More sharing options...
hypergear Posted November 23, 2013 Author Share Posted November 23, 2013 Some results sent through DMD tuning this evening: From a high flowed Rb25det Neo turbocharger, supporting mods, pump 98 fuel Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/452/#findComment-7119701 Share on other sites More sharing options...
GTSBoy Posted November 23, 2013 Share Posted November 23, 2013 How am I supposed to react to an inlet air temperature that is hotter than the surface of the sun? 3 Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/452/#findComment-7119741 Share on other sites More sharing options...
Marcus89 Posted November 23, 2013 Share Posted November 23, 2013 Hmm well its not a BAD result, not at all.. 250kw all in between 3500-4000 is pretty good. It definitely tells me that the turbo is doing its thing and its doing it well.. If there is a 'problem' it is somewhere else on the setup. A 2.5 is probably good for 270 max, and there is no guarantee that a given motor combo can draw the max from a given turbo. Have you asked your tuner what could be causing it? I find its easier if you tell them it has a brand name turbo they tend to listen more and try harder when they think it has an expensive brand name on it, like Garrett or GReddy. This is very true didn't seem to matter how much I told them that the turbo is very good and has had a lot of testing done to be a proven performer they just kept saying nope the turbo is crap get a good one.... The tuner said that if they ran more boost it would ping/get too hot. I have done leak testing of my system and can't find any major leaks. Does slowly lose pressure over a a couple minutes though. Some results sent through DMD tuning this evening: From a high flowed Rb25det Neo turbocharger, supporting mods, pump 98 fuel Seeing results like this make me wish I had stuck to highflowing my neo turbo would have been a little less hassle and would of gotten similar results although is that boost line accurate? Is that car really only running 16psi dropping down to 13 for that power? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/452/#findComment-7119894 Share on other sites More sharing options...
hypergear Posted November 23, 2013 Author Share Posted November 23, 2013 This is very true didn't seem to matter how much I told them that the turbo is very good and has had a lot of testing done to be a proven performer they just kept saying nope the turbo is crap get a good one.... The tuner said that if they ran more boost it would ping/get too hot. I have done leak testing of my system and can't find any major leaks. Does slowly lose pressure over a a couple minutes though. Seeing results like this make me wish I had stuck to highflowing my neo turbo would have been a little less hassle and would of gotten similar results although is that boost line accurate? Is that car really only running 16psi dropping down to 13 for that power? Yes that's what the tuner sent in so I assume all the data are correct. The G2.5 is a bigger turbocharger using a .82 rear housing, by high flowing a .63 OP6 turbined turbocharger I believe it will be straggling to pass 230rwkws on your car. And not sure if this has been posted. It is a standard R33 21U high flow with current profile doing 271rwkws on pump 98 fuel. It does have a set of drop in pon cams.: Note the actuator used is factory. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/452/#findComment-7119957 Share on other sites More sharing options...
GTScotT Posted November 24, 2013 Share Posted November 24, 2013 This is very true didn't seem to matter how much I told them that the turbo is very good and has had a lot of testing done to be a proven performer they just kept saying nope the turbo is crap get a good one.... The tuner said that if they ran more boost it would ping/get too hot. I have done leak testing of my system and can't find any major leaks. Does slowly lose pressure over a a couple minutes though. That's fairly standard.. what pressure actuator do you have on your turbo and what was minimum boost when you went for the tune. Also, what tuner was it? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/452/#findComment-7120027 Share on other sites More sharing options...
Marcus89 Posted November 24, 2013 Share Posted November 24, 2013 That's fairly standard.. what pressure actuator do you have on your turbo and what was minimum boost when you went for the tune. Also, what tuner was it? It is a 14psi actuator with the preload it has on it the turbo spikes to about 20 then tapers down to 17psi. Am using an MBC also. Tuner was Hi-power racing in Slacks creek they are more Honda guys but the tuner they have there Ben does a lot of nistuning stuff Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/452/#findComment-7120224 Share on other sites More sharing options...
hypergear Posted November 24, 2013 Author Share Posted November 24, 2013 Well I can swap you with a current high flowed R33 turbocharger and physically set the wastegate to hold 20psi without any boost drops. If that don't make power you might want to have a look into the supporting mods you've got. Since you are in Brisbane, I recommend going to see DVSJEZ. PM through if interested of doing so. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/452/#findComment-7120573 Share on other sites More sharing options...
Super Drager Posted November 24, 2013 Share Posted November 24, 2013 Pretty sure Jez is on the central coast in NSW Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/452/#findComment-7120603 Share on other sites More sharing options...
Manuel Kasko Posted November 24, 2013 Share Posted November 24, 2013 Haha yep pretty far drive from Brisbane to Jez's place Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/452/#findComment-7120838 Share on other sites More sharing options...
hypergear Posted November 25, 2013 Author Share Posted November 25, 2013 Did some evaluation and testing today based on the differences those Tomei 264 / 9mm cams. In which Tomei should have done before considering selling those to the market. The difference is. Well, 3Kws in power and 350RPMS in lag. By saying lag means Laggier with Tomei. The Test turbo was a SS2 Alpha with VNT turbine. My original result was: Same turbo, Tomei 264 / 9 Cams: \ ^^^ Notice the difference in response from stock cams. In conclusion the lose in response is 350rpms, which is greater then the gain using VNT turbine system, resulted in a laggier then usual 386rwkws. and I'm unsure of what those cams are good for, been secretly promoting them to few selected retailers, perhaps tomei haven't figured it out them selves. A T04Z or a School bus turbo perhaps. Those cams will be shortly removed and auctioned off on ebay. I'm rather disappointed. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/452/#findComment-7121264 Share on other sites More sharing options...
hy_rpm Posted November 25, 2013 Share Posted November 25, 2013 Just don't look at the boost response look at the power bands Poncams vs std 4000rpm 250kw vs 225kw 5000rpm 350kw vs 300kw Should have got a dyno printout overlaying the old result Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/452/#findComment-7121269 Share on other sites More sharing options...
hypergear Posted November 25, 2013 Author Share Posted November 25, 2013 It had more boost in those areas on today's run. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/452/#findComment-7121274 Share on other sites More sharing options...
hy_rpm Posted November 25, 2013 Share Posted November 25, 2013 Yeah just 1psi but it also takes longer to reach if the boost is set higher but at 20psi it still got there at 3500rpm See if Trent can overlay today's results vs std cams and will be a better comparison Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/452/#findComment-7121463 Share on other sites More sharing options...
Manuel Kasko Posted November 25, 2013 Share Posted November 25, 2013 Stao is a high flow r34 turbo a direct bolt back in? Or does the size change and there for the water lines etc need a little adjusting? Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/452/#findComment-7121638 Share on other sites More sharing options...
hypergear Posted November 25, 2013 Author Share Posted November 25, 2013 Yeah just 1psi but it also takes longer to reach if the boost is set higher but at 20psi it still got there at 3500rpm See if Trent can overlay today's results vs std cams and will be a better comparison True, how ever it is still playing the power / response trading game. As the down low area of the power curve is now shifted to mid top. SS2 Alpha is a very responsive turbocharger, if a standard SS2 is used then I won't be expecting 20psi till 4100rpms. Tren't computer is some times unstable as it crashes. It crashed after we printed my last SS2 alpha run and lost the dyno plot, So we can only compare paper back at this stage. Stao is a high flow r34 turbo a direct bolt back in? Or does the size change and there for the water lines etc need a little adjusting? High flow R34 turbocharger would bolt in straight. It will still need a tinny bit of a twick on the water lines, but not as much as whats on the SS1PU. Link to comment https://www.sau.com.au/forums/topic/261613-hypergear-turbochargers-and-high-flow-services-development-thread/page/452/#findComment-7121665 Share on other sites More sharing options...
