Also, can i get a rollcall on who is using what dump pipes with their turbos. I was using a (very old) JJR Bellmouth with an internal gate SS2 and the wastgate flap was fouling on the dump.
Thinking about buying the same thing again, but want to see what others are running, as smoe form of boost control would be great :)
Your exhaust is fine and is making good power. No need to change it. Unless the new one glows in dark.
Yeah, should be able to do that. I have a track day this Thursday, so if nothing blows up, I'll be in.
Car was originally tuned at Unigroup (290 as well- their dynos are identical I've found from personal experience), however I use DVS Jez, and has been to him quite a bit. Stock S14 motor, incld headgasket. GTX3071R 0.82 housing, 6Boost, 44mm Tial. 289kw@18psi on 98.
Lets go and see what they do, if I make it through the gearbox! :P
That is a awesome power figure and only 18psi boost on 98 should be very safe and easier on the box with the .82 rear
How did you find drivability wize going from Unigroup to dvsjez? I'm tuned at Unigroup now
If you went with a .63 rear and more boost and e85 would be very different to drive but may be abit harsh on the driveline as the .82 will be slighty laggier
I do welcome discussions about SR20dets as I'm learning about it my self.
Here is the dyno reading form the S14 I've just bought, with a GT3071 turbocharger appears to be in a .64 T2x turbine:
The response on paper is bit better then I anticipated. Its made 22psi by 4300RPMs.
Very little power for the amount of boost given. Its lake of down low torque, drives like a NA most of time. The sheet does how that which makes 120kws on 4000RPMs. Same power with 300RPMs better in response would be nice.
Other funny thing about this S14 is it appears that they've hidden all the electrical wiring. There are no wiring or fuse boxes any where inside this engine bay. Electrical work would a nightmare.
I'm modifying my factory Rb25det exhaust manifold at moment for external gating, how ever it will be externally gated on two different spots of which I think been the highest pressure points. Will upload photos once its done and be interested to see how much difference in power I might be losing from the Brae high mount with a factory bolton version of SS4 Alpha turbocharger.
I was running an X-Force 3" Bellmouth dump with my HKS turbo, never had an issue with it. Its now been chopped/modified to a v-band and wastegate plumbed in.
Car sounds so awesome on the new engine, its not just turbo noise all the time like it was with the HKS turbo, sounds raw engine, love it. The SS2 is so much quieter driving around off boost, I've only hit about 3psi so far as I've only tuned it enough to just get it places, but I think its going to sound/go pretty good at 24ish psi :)
Got a 4" intake made up today, its a bit busy around the exhaust side of the engine. Few more things to sort out but should be getting tuned in early January:
The turbo outlet silicone hose will burn quickly if you let it like that. :(
I've seen some setup on SR with a silicone hose close to the exhaust manifold like yours, and the hose never lasted long.
Lol did you know it was like that or found out after trying to tune?
Looks like your car has had a big rear ender.
Nah it was fine when it was tuned. Had a car transport company move my car and this is how I get it back from them. Not sure how they managed it, bunch of special people.
Yeah think we are going to change it to a steel pipe with straight joiners
Ive done that once before with my dumpipe lol backing out of a driveway and the runner the electric gate runs on my flange caught it and completey bend the dumpipe at both those bends just like yours haha.
Id suggest getting a 90 degree elbow welded off the housing 89cal
Edited by methz
Reversed the car and caught the exhaust on something..
The fact it actually bent like that indicates the pipe was pretty hot when it made contact, and also that it was quite an impact. Indicates to me your car was doing burnouts, lost control and went backward over something that got caught on the exhaust.
Let this be a note to anyone having a car moved by transport; you MUST have a 'mechanic' limit put in for such reasons. Something that drops the rev limit to 3,000 or similar. Or pull the AFM earth out of the plug. It will be too hard for them to work out and will make the car run in limp mode.
This i have recently found out :P And will be doing the same!
I always keep a few 90 degree silicon bends in the garage for this very reason lol. but also depends on manifold design and how close runner 1 is tucked into the collector.
I had the same design dumpipe gtscott its just got weak points and is cheaply made. I was reversing and wasn't going fast or was the dumpipe hot at the time.
Edited by methz
Lol didnt see that coming.
The jjr is ok. Need to die-grind their dump flange abit. From memory it didnt match up with factory gasket.
Posted Image
Posted Image
Getting the VCt to work and std manifold back on will bring back that 300rpms or more response should be more around 200rwkw at 4000rpm
But remember the sr20 is not like the rb25 with 2 less cylinders
I have had them hitting under the floor too, I would say their jig was bent at various times and they just kept pumping them out. I guess for the price you can't complain.
I just purchased one today, so hopefully it only requires minimal modification.
Yeah I've got JJR too, it's fine. I had the workshop to shave back the flange as per these instructions, and also had a flexi join installed just after the bottom bend as the mid muffler scrapes every now and then and I don't want to wreck the turbo. Works well.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
