Yes, we did get the Adaptronic tuned running. The internally gated VNT turbocharger didn't work according to plan, but I did get plenty of data for further research work.
Regardless, VNT internally gated system is proven working, and have made a difference in turbocharger's response:
If I have time finishing off the newer prototype, it will be trailed again on the 29th.
Finally got my car tuned. The thing pulls damn hard. Will get a dyno run in the next few weeks to see what its making, there may be a very slight exhaust restriction that is affecting (very slightly) the boost right up top, but feels pretty damn good anyway :D
It feels rediculous to me, easily spins the 265s on the rear in 2nd and can keep it going through 3rd. My tuner said he had a hard time smooting the boost because it was so aggressive lol....
love it so far. Going to see if i can get it on a dyno before I go back to work wednesday but may not happen between now and then
Reminds me of how I feel about my SS1PU :)
Honestly the dyno lies to me, comparing my cars to similar examples with non HG turbos just feels unfair. Mine is so raw and aggressive.
Hey Stao
If i send you my stock manifold and my ATR43G2.5 could you do you custom external gate mod and make the rear housing external gate.?
( and update turbo revision if any better than mine ~ 1.5 years old )
I can upgrade it to the current SS2 for $250 if you prefer, and ask M35scotty to do the external gated rear housing mod.
How ever I have picked up a lot more power from externally gating through factory exhaust manifold, it is preferred if you can do the same. See if Scotty can do that for you.
If the ss2 is better sure,
As for externally gating, that would be the new gate off the manifold you tested start of January yes?
Would you need to put a different rear housing on the turbo? Or do u just weld internal shut?
Also, i cant seem to find Scotty's details... i must be blind :S
Is he over east?
Is he over east?
Isn't everyone over east? :P
Stao only uses one casting of .82 internal gate housing for skylines as far as I know, I have asked him for an external housing a few times but it would obviously blow the cost out, as he is tooled up to cnc the internal. I can weld a gate to the housing easily as I have a jig and know where the gate will clear. You would need to organise your own screamer/plumb back pipe locally.
I have to jig up a stock manifold for a suitable gate position still, so I can't really make one until I have an rb25 on the hoist, and a spare manifold. I was hoping to get over to Stao's to check his out, but he is the other side of the city, and we are both too busy atm. Hopefully I could sell it as a kit eventually with the gate and screamer pipe, but is there much of a demand for this setup? I would need to set up a cash back on return system for the old stock manifolds.
Welding off the housing would be best for shipping purposes obviously, and there are so many cheap options out there for housings now, like the stainless Vband Tial copies I use on my car, which make turbo/exhaust swaps so easy compared to the 6 bolt Nissan.
I has a few spare rb25 stock manifolds :D
Hi
Since the turbo is being rebuilt , is it okay to get a blown turbo and send it to you to be rebuilt with the standard highflow service for $800 + gst?
Cant leave my car of the road to remove turbo so thought this would be the best option
So I upgraded to the SS2 after blowing my tr43i and got it tuned today here are the results. Made 343kw on 18psi on a very conservative tune it has much more in it if I wanted to but my aim was 350kw as more power is useless to me on my drift setup.
Comparing it to my old turbo the tr43i that made 340kw on 21psi with the same response but with more timing along with 3psi more and the turbo was really being pushed to its limit especially with the 0.63 rear. Overall very happy with the result as expected the turbo performed excellent. Also btw my setup consists of all the usual bolt ons, brae top mount mani and hypergear 50mm gate for ppl that dont know.
post-50426-0-79844200-1390380431_thumb.jpgpost-50426-0-24964200-1390380494_thumb.jpgpost-50426-0-59164700-1390380554_thumb.jpg
  • Like 1
Hi
From the website:
Condition of the donor turbo. Donor turbo can be blown, with broken fins, or damaged wheels. Cracked housings depending on the extend of damage has to be repaired prior profiling. Clients will be informed if repairing work is required, quotes will be given before additional work taking places.
Good work spoke to Trent and he was talking about your car. Saw your car outside too!
Copy pasta
In for a tune with Trent today but got an issue I need to fix
So in for a tune on the new turbo.
But there is an underlying problem with the car. At this stage it may be the injectors. So we are going to pull them out and flow test them
In coming to this analysis we switched to e85 fuel, so will probably just stick with e85 fuel.
At this stage the car makes 315rwkw at 4,500 rpm. Trent thinks it will get close to 400rwkw once the issue is fixed.
ahaha yeah looks pretty beaten up atm. Was that your car the black one in the dyno when I was leaving?
What turbo are you running on it now?
ATR45. So a copy of a 3582 xr6turbo. Slightly smaller than a Garret 3582.
Internal gate. Stock manifold position
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
