awesome who did the ex gate for you? Looks really good. I'll keep an eye out for your results mate I hope your excited
Scotty did!!
Common for them rub on the top guide
Some people remove it
I just space it up with washers and use a s15 chain tensioner as it has finer adjustment otherwise you have to replace the timing chain and guides as it has stretched or the guides are worn and you have to remove the cover to do so which means engine out head off and int sump off
This engine did cost abit of money to build, its worth while taken it back to the engine builder making sure there is nothing going funny. But thanks for the input I will have a S15 tensioner installed.
By the way is the ATR28SS15 installed in yours? How does it feel driving around on road?
Worth taking it back to the engine builder if yours rebuilt not long ago and it's a engine fault
I've been very busy lately and haven't had a chance to put it in yet
will put it in 2-3weeks time
Evo should be tuned wed so should have results to put up
Got the evo 8 tuned today
Made 285awkw on 25.5psi with more in it but tuner was not happy with winding in more boost on stock block
Power was still climbing with more he boost he said
I reckon would have cracked 300kw on 28psi
I'll get a dyno sheet up later
Evo 8 stock block
Fic 1120 cc injectors
Deatchwerks 300 fuel pump rewired
Caltex eflex
K&n panel filter std airbox
Ces racing exhaust turbo back split dump pipe screamer
Gsc s1 cams
Hypergear slss2 hi flow evo 9 turbo 25.5 psi 4400-4500rpm
Edited by hy_rpm
It was a kando evo9 turbo with billet comp before and made 256kw on same boost 25.5psi by 3600rpm
I really want to see the 300kw number so on a rigoli dyno day I'll get him to try 28psi and see if I get there
I should start building evo turbos. :rolleyes:
That configuration stopped making power on a Rb25det at 383rwkws E85 proper manifold and externally gated.
Take 15kws off for factory manifold and 30kws off for internal gate. Then I should have 338rwkws.
Take the Evo's 4WD trans lose (assume identical to a GTR) is 12% then the 285awkws is 319rwkws out of a RB. There should still be another 18kws that you can squeeze out.
I'd like to see a Mivec head on a 6/7/8 engine using the larger aftermarket TS turbine housing . Taos mentioned the losses of std manifolds and IWGs on RBs and I imagine you'd lose a bit more if RB25s didn't have the inlet cam switch even as basic as it is .
Anyhow Mivec tames things down at low revs and I think even in std form one of the cams is hotter than earlier factory ones . Taming down means less loss with healthier turbos but all business when the revs are up and cam timing switches to lets go get em mode .
Evo 9s were getting pretty heavy for a 2L car and Mitsy were using all the easy things to avoid adding more capacity .
Lots of aftermarket manifolds around for Evos now and I think FP is doing a larger bore cast manifold which would be handy if it looks std .
Possibilities .
Didn't you say smaller engines usually make similar outright power but there just need more boost usually
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
