I already said the comparison is pointless unless we use the same dyno with same car. I didn't make any of those sheets either.
To get 200rwkws with 3076 .82 by 4000RPMs that is possible with race fuel and cam gears which you can add heaps of timing down low. But I haven't seen any one made that with all stock parts.
Or use a 71mm comp wheel with cam gears. But I think its hard to crack 300rwkws with 98 fuel.
I can't find any that come even close to 200rwkw at 4000rpm... Care to point me in the right direction?!?
See this is a baby 52T ATR43g2 high flow in .63 rear with cam gear and 98 fuel. Its pretty close to 200rwkws by 4000RPMs. But Its going to be maxed around 270rwkws ish. If you run Race fuel in that you will get more then 200rwkws by 4000RPMs maxing out at 300rwkws.
No race fuels, no cams. They do it.
I dont wish to debate the garrett vs your turbo, I just wanted to point out it was a poor comparison.
One further thing you may want to consider is how long the curve stays concave. The above graphs show the 3076 has a far more convex curve. This would be highly appealing to many people looking for as much area under the curve as possible.
SimonR32, majority of results I found were on this site, search and yee will find. It has been some 6 months again, I since purchased a 3037 (and ironically am now selling it) and havent looked since.
For once more I've said the comparison is pointless unless certain conditions are met (which is not), and I'm not the person who posted them or responsible for their actions.
I've seen Simon-R32's results. How ever that is running off .63 rear housing with a 44mm external gate alone with all other mods. If I do all those to my test car then I can also get his result. He's not running 98 fuel either.
After reading through his thread and understood what he've gone though for his result would you just bolton a 3076 in .63 int gated rear to your factory setup and hopping for 300rwkws with pump fuel?
How ever my goal is building a solid bolton turbo that can produce such power with less as possible modifications done to the factory package.
If I modify my car to the stage as his and selling my services to others based on that result, I call that fraud. I'm not trying to modify my setup to bring out the best out of a turbo, but trying to build a turbo to bring out the best of a "stock setup".
To me GT3076 in .63 rear internally gated can not make a genuine 300rwkws with fully stock setup and 98 fuel. From my experiment It will drop lot of boost with standard actuator, replace it with a high pressure valve and gate controller, it creepes so much heat that turned it self red hot and you lose power after every run.
Look again, I think your memory has failed you :)
Look again, I think your memory has failed you :banana:
I agree, I cant see any 3076s (0.82 housing) that make 200rwkw at 4,000rpm on 98 fuel.
I can see a few HKS 2835 Pro S setups that make 200rwkw at 4,000rpm but even they need E85 fuel for that.
The target is 100-120 KPH as most graphs are in speed rather than RPM.
With different ratios or wheel sizes this is an approximate marker for the 4000RPM range in 4th gear.
I remember feeling entirely the same, all the 3076 rage rah rah rah, smaller turbos are far stronger down low etc etc. Some better investigation brought that 200kw marker to light.
The graph above for the 52T is showing 200KW @ 4200RPM at 17psi, look at how much earlier the boost comes in too, the 56T would easily exceed that at that point. Its on full boost by 3450RPM, do you really think the 56T will be 1000RPM laggier, no. But it will flow a considerable amount more at that point.
Flow = power, direct relationship. < thats a full stop.
So the turbo above doesnt even meet your requirement of 200rwkw @ 4000rpm but your saying a larger turbo (56T) will?
Surely with the number of them out there a real life example would be available if it was such an easy thing.
Using wheels speed is inaccurate unless you know diff ratios, wheel/tyres sizes etc. and this is why you are being misguided!
The 56T is a 0.84 rear and 52T is a 0.63 rear, so a bigger compressor and bigger exhaust housing would make for about 700-1000rpm laggier yes!
Edited by SimonR32
Which is why I have not made point to be exact.
It has also been documented that there are gains to be had in the larger housing over the smaller one. The added volume aids in lower combustion temperatures and more timing can be wound into the motor.
One correction to my 'claim' that has shed many a tear it seems, results were more consistent when using an exhaust cam gear.
You are comparing Dyno Dynamics readings with a Dynapack reading - it can't really be done.
yes it can.... Dynapak has a correction mode that will give it DD readings to within a kw or 2 :banana:
a well tuned RB25 with a 3076 should achieve close to the 200rwkw mark by roughly 4000RPM. I am talking about an internally standard motor, no cams.
on pulp... a 3071/2835 will just make it... but only if you reeeealy push it
fwiw...
this is my car: tuned on the same dyno (trent @ status)
unopened RB25 with an HKS 2835 pro s, (3071 w HKS spec .68 rear). I am running a greddy rb26 ex cam gear, hybrid GT intercooler, stock throttle body, plenum etc
the red line is BP ultimate and the blue line is manildra e85
@ 4000 rpm pulp makes 190rwkw and e85 makes 210rwkw
Larger the trim is the more vertical power behavior you get. To get a smooth build up of power you need to run a large comp housing with a small trimmed mid size comp wheel.
I wouldn't call the smoother the better. turbos do produce this vertical power increasement has a very sharp and strong punch on acceleration. while the build up turbo would give a lot smoother sort of feel.
But if you are dragging, The car that reaches peek power and torque quicker is more likely to win.
We can build them to do either, so I would say it depends on people's preferred driving ability.
I think your above power curve of the ProS is similar to this one here:
Its a customized GT30 wheel running on stock cams and 98 fuel. That would be the most responsive towards 300rwkws as you can get. Car wasn't strapped down, had plenty wheel spin.
Wow! Full boost before 2500 and 250 killerwasps!
Dragon eggs for sure.
Yes Stao I do agree the concave curve would feel faster, although I disagree that it is likely to win. I would say it is fair to say it would have more traction issues for the same final output :banana:
Only issue with that last dyno plot tao is the power falls over after 5,600rpm. I wonder how far it would fall if you kept going till 7,000rpm?
But yes its quite responsive, very impressive. Hard to have everything I suppose.
that's true... the 2835 is still going strong by my 7400rpm limit (not on that particular 6800 graph, just take my word lol)
Is the exhaust housing the the only difference between the HKS 2835 pro s and the Garrett 3071?
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
