For a track car I would go for a turbo that gives you a broader area under the graph, not just outright power..
SS2 would be a perfect choice, gated & on happy juice
The set up will be externally gated...
Yer gives me something to think about. have to pull the trigger and make a decision soon tho....
Pretty much if you know your going to settle for 360kw then might aswell go for ss2 and gain the response but if you want more or are unsure if you will want/need more then upsize.
  On 06/03/2014 at 10:49 AM, iruvyouskyrine said:
How much power are you making Manuel? I saw how hard your car bakes, can you give a quick rundown of power/mods?
343kw at 18 psi on e85. Mods are ss2 turbo, brae manifold,50mm gate, and then the usual bolt ons like pump injectors pfc etc. stock engine apart from tomei poncams.
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page-463
Thanks for that!
The external gate adapter (for lack of a better word) plate thingy that you provide stao, is it 3" V-Band outlet?
If not can I buy a Kando GT3076 .82 rear housing and put it straight on?
Thanks.
They can be made to a vband, usually is a plate to weld a dump pipe to. My turbine is larger and has different radious to 3076 so if you are supplying the housing, i will need to remachine it.
Car was tuned today!
I bought a blown R34 OP6 turbo off eBay specifically for Stao to do a highflow on. I chose the larger turbine mainly for the extra ~30kw it produces over the 21U housing. It is 500rpm laggier than the standard R33 highflow, according to Stao.
Firstly, installation was pretty straightforward. Both coolant lines had to be tweaked slightly to suit the new CHRA, but the oil feed and return were both direct bolt-ons. Obviously intake and dump pipes are exactly the same as standard.
Basic Specs:
1996 R33 S2
Unopened engine, 104,000km. New timing belt, water pump.
HyperGear OP6 highflow.
Nismo 555's
Z32 AFM
R33 GT-R fuel pump with +12v direct re-wire.
Scotty's intake pipe, A3 POD filter (for now).
JJR Return flow FMIC
JJR Dump to Venom Cat to Apexi N1
BP98
Glamour:
And the dyno result:
Current tune is red, overlaid on the previous tune, which was stock turbo, injectors and AFM @ 11psi.
Verdict: Car feels a lot less punchy under 3000rpm, which I expected. Turbo comes on song at around 3,800, with full boost of 19psi at 4000rpm. It hits hard and fast, where as before with the stock turbo it would feel quite weak in the upper region of the tach. Very happy with the power, and it is still very driveable around town, just less aggressive down low. Fuel economy TBA :P Might go e85 later down the track.
Big thanks to Stao and Trent for their awesome work :thumbsup::D
Edited by colourclassic
Nice result, did you have any issues with the jjr dump? I'm doing the same mods, but found the dump has a 10mm step at the bottom, (ie needs opening up to prevent a restriction)
Looks like there isn't enough meat on the flange to die grind, so will have to crack ze welder out and fix up.
I've got the ATR43SS2 (i.e. not a high flow) and it works well with my slightly tweaked JJR dump. However the IWG part of the housing is probably a bit different to the OP6.
Here's a post on shaving the JJR flange, not sure if that helps: http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/?p=6590457
I ported/die grinded mine ;)
Basic Specs:
1996 R33 S2
Nismo 555's
Z32 AFM
BP98
Thanks for sharing. This is an excellent result. I'm very happy with how the new wheel configurations performed. Even on a R33 Rb25det it still managed to hold very steady power and torque in upper rev rang, which usually dips after 6500 on stock manifold internally gate.
I have one more results form a recent customer, with a OP6 high flow based on a R34 GTT. Which managed similar result of 271rwkws on pump at 18psi:
I've been working on few new turbos for the time been. photos and results will be posted shortly.
With JJR dumps they need go through some serious die-grinding, they are then good to use.
I found JJR's return flow coolers get hot pretty easily, while plazamaman, PWR and most of Jap brands stays cool for much longer. Might be the next upgrade to try on.
Trent mentioned how impressed he was with the boost curve, it locks on to 19psi and holds it well all the way through. That's with a basic TurboTech MBC too.
Racked up about 80km tonight around Melbourne - gotta say I'm pretty over the moon with how this car performs now.
  On 14/03/2014 at 9:33 AM, GTScotT said:
I believe that to be a great result. Be sure to report back with drag results if you ever go.
I'm keen to go soon and find out!
  On 14/03/2014 at 12:38 PM, CEF33Y said:
Yeah my dump needs a lot of work, I'll sort it though. The little rb20 is going to need every bit of help running a op6 high flow, lol
I found it pretty fun porting mine. I just laid the OEM Nissan gasket on and traced with sharpie what needed cleaning up. Make sure you get a nice smooth transition and don't penetrate into the welds and you'll be all good.
Wow epic result and sex wheels, mind sharing size and offset?
I've been a lazy prick with my car, I'm picking up a new ECU tomorrow and I'll start tuning soon.
I don't think anyone has configured their SS2 like mine yet so it should be fun to find out what it does.
Will share results and timing maps once I start.
  • Like 1
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
