It's a system. Compressor + engine + turbine determines if the compressor will run out of flow or not. Put a small back end on and you may not run out of compressor flow and so hold boost to the redline. Put a larger rear on it, relieve the back pressure on the engine, might be another story entirely.
I like the analogy used on here the other day (in some thread or another) about comparing apples and oranges to work out which is the best banana.
  • Like 1
Some update, did some tuning last night and ramped it up to 1.1 bar already.. appears my stock injectors are about to hit a brick wall. I've dialled in more fuel however I've notice I had to add in heaps to get it under 11.8 AFR.
For those interested, attached is my fairly relaxed timing map :)
I tried to add more timing after 5000 rpm, but experienced some knock around the 5200 ~ 5600rpm part (which does't make much sense as I'm past max torque). Will check my CAS again.
^ hahahhaa.... I'm on a budget man, this Adaptronic ECU was super impulse buy @ $700 !
I was planning to stretch Toshi's remap till after the financial year, but this was too tempting LOL
NAOOO to top rail, CBF.. too much effort LOL
Can you get 1200cc OR 1000cc sidefeeds? we can talk after my tax returns haha
I have a spare set of brand new FiveO 1200 CC for $750 if interested.
The 16g is abit small for what I was after, might be shifting that to the SS1 turbine and see which one is better out of the two.
I will be evaluating the current 18.5 or 20.5G billet comp wheels down the track.
The only side feeds I can get are the 550's, as that's the largest they made from the factory. Anything larger is a 'highflowed' injector, essentially drilled out.
Top feed rail and Xspurt 1000's are an easy upgrade, and would cost around the price of the FiveO injectors alone. Local warranty can come in very handy too, it can cost more than the injector is worth to send it back for warranty replacement.
hrmmms.. let's see after tax returns :)
The bank account isn't happy at the moment, from my impulse buy lol
No the std evo 9 turbo with cams and supporting mods have no issue at holding 25psi till redline on my brothers car evo 8 before he got it flowed by Tao
The ss1.5 is even larger more like 20g size
Actually the SS1.5 is smaller then a 20G. That one which you've sent back originally was a 20G size. Regardless the compressor don't matter that much, the turbine side is the one needs to be worked on.
The SLSS2 stopped making power at 385rwkws at 23psi on my R33 externally gated on high mount. Usually smaller engines needs more boost getting the same power level. How ever the EVO is internally gated (stock manifold?) The easiest way to determine wither the turbocharger or some thing is maxed out is by judge the amount of power gain per psi of boost added. The percentage starts to decline sharply when that happens, and best leave as that. By calculation this the SLSS2 will max out at 299awkws at 29psi. Did that evo ended up adding higher boost for the dyno show?
Well it advertised off kando as a std evo9 16g6 but billet
Even though it was a 20g it was responsive 25psi by 3600rpm
But even people with the standard cast evo 9 turbo get the same results
My bro evo should be coming back today from tuner got head stud installed aswell as 30psi
Stao what about run a big compressor wheel in a small turbine housing then use a large internal waste gate to compensate heat and flow? I have seen few turbos from Euro cars been made that way like the Audi K03 and K04. Might be a good thing to try on.
Keen to hear the SLSS2 results, please update!
I thought the recent post to Evo Oz was actually SLSS2.. So it was actually the Kando thing?
    • Came here to say, put all the wiring from the new motor and gearbox in that you can, then throw the stock ECUs in the bin, and get an aftermarket ECU. Should be pretty easy if you can use a multimeter and read a wiring diagram to then use a PNP aftermarket ECU to suit the motors wiring loom, and make the minimal changes you will to get it to work in with the body loom (If any). This will mean you can very easily circumvent/bypass the Park/Neutral start disable switch, and get everything running really easy!
    • If the roof is dual skinned the whole way, IE, there's a "top" metal piece, and a "bottom" metal piece, to slow it down as much as you practically can, you should be able to get an attachment for a spray can/your spray gun, where it is a long, thin flexible hose, and when you're "spraying" it is spraying it in every direction possible. The I'd get that, and feed it through the roof as much and as far as you can. It's basically like fish oiling the car, but you're soaking it in rust converter. Then do the fix like Murray has described having cleaned up the existing metal as much as you humanly can. I'd also throw as much rust converter on that exposed metal before putting the fibreglass/metal filler over everything.   As for welding a replacement in. I've owned my own MIG welder for about 10 years. I've also worked in an industry doing MIG welding for a job for about 3 months dead straight, and we were doing 11.5 hour work days 5 days a week, plus a Saturday 6 hour day. (I then moved over to running the massive CNC plasma as I could understand the technology, and work with the main guy out there). I also f**k around with my welders a bit at home. So what I'm saying here is, I've probably got more hours on a MIG gun than you'll manage to get under your sleeve doing home sorts of jobs over the next 5 years. I also have an ACDC TIG that I got myself a year or two back. I've got a short amount of experience on the TIG only. My home MIG is also presently setup for doing thin sheet metal. Unless I didn't care about how that roof looked, and I just wanted a functional metal roof, and it being out of alignment, warped, and bowed, I would NOT attempt a roof replacement UNLESS I could do it as a whole panel like Murray described where the spot welds were.  Welding has this REALLY annoying thing, where if you want something to be perfectly square, unless you can clamp that thing to damn perfection (Welding fixture table), it is NOT going to be square, so you start to learn, the type of metal you're working with, how thick it is etc, and weld in VERY specific ways, and by knowing how YOU are as a welder, so that as the welds cool, the metal work pulls itself into place. If you want to see some cool tricky shit done, Bennets Customs is an Aussie guy, and he mentions a guy a lot call "Kyle", who is from "Make It Kustom". Watch some of their welding videos, especially on sheet metal. You can use the welder to shrink the steel in, and you can also use the welder to stretch the panel out. When you have the skill level that I have, you can shrink the metal in and out... But never on purpose like those two guys do. You just manage to f**k it all up. Then I smack it around with a hammer till it sits lower than I will want it too, then I shove filler on top and then pray to deitys that I can sand it into some form of sane shape that doesn't look like a dog has taken a shit, after eating a tonne of pumice stone... I'm all for DIY, and for learning, and please, feel free to give it a go, but be aware, you need to live with the consequences of how time consuming it is to do, AND that it's going to look no where near as good as what you can make it look with just some filler now. Oh AND, even once you replace it, it's like to still rust away again eventually, because you'll have missed putting primer and paint on some part of the newly welded in sheet metal, or against part of the existing metal you couldn't get to...   Oh, and to weld all that in, you will need to pull the window out, and strip at least the roof and A Pillars of interior trim and wiring. You'll then need things like the big fire proof/weld spatter proof mats to lay down, OR you'll end up needing to strip the ENTIRE interior to avoid sending it all up in a ball of flames. If you want to see how annoying sheet metal is to weld, head to bunnings, buy there 600x600 1.6mm mild steel (Not GAL!) sheet, and cut a few pieces, and try and weld them together. Then understand, 1.6mm sheet is nearly 50 to 100% THICKER than the cars sheet metal.   The photos I posted before, I'm replacing with 1.2mm thick mild sheet, and it's very easy to blow through both the original steel (Especially if I hit an area that should have probably been cut out a bit more) or straight through the new sheet metal. And I'm doing the floor, which can be hidden easily, and doesn't matter how pretty I make it, as long as it's damn strong! I'm also doing it in a 4WD, that has seen many off road trails, and doesn't need to look that pretty ever
    • This sounds like a perfect excuse to install a Haltech R3.
    • I do believe from context he is talking about a S0/S1 R33 RB25 with associated ECU and Wiring for that, and a manual gearbox into a R34 N/A Auto. I don't have the knowledge of all the pinouts and such but my gut feeling from doing my own conversion is to use as much of the R33 stuff that you can. The "car" wiring is quite seperate from the "Engine" wiring when all things are considered. The only things to truly consider 99% of the time is the cluster, reverse lights and potentially disabling the 'not in P/N' immobilizer circuit.
    • A realistic expectattion of how long it has to last also comes down to.... when do you think you will be banned from registering and driving old petrol powered shitters? It's 27 years since that thing was built. It probably rusted out 15 years ago. It was probably repaired and looked OK for another 10. If you do a similarish bodge job now, or perhaps slightly better with some actual rust conversion and glassing, then.... get another 10-15 years out of it, after which you'll only be permitted by the CCP to drive electric cars manufactured in their Shenzen zone anyway.
