Evo 8 stock block
Fic 1120 cc injectors
Deatchwerks 300 fuel pump rewired
Caltex eflex
K&n panel filter std airbox
Ces racing exhaust turbo back split dump pipe screamer
Gsc s1 cams
Hypergear slss2 hi flow evo 9 turbo 25.5 psi 4400-4500rpm
SLSS2 is making 285AWKWs so far. I think it will stop making power just under 300awkws at 29psi.
Stao what about run a big compressor wheel in a small turbine housing then use a large internal waste gate to compensate heat and flow? I have seen few turbos from Euro cars been made that way like the Audi K03 and K04. Might be a good thing to try on.
They only work with low boost level applications, some thing under 16psi would work great. The compressor and turbine end must be welly balanced. As in the back pressure needs to be similar to boost pressure so forces generated naturalizes.
At moment with the SR its matter of evaluating different wheels and housings for some data. Once the limitation of compressor and turbine is determined, I can then mix-match or make some thing very specifically to suit either end of the turbocharger. That way I have a balance flowed turbocharger that makes good power for its response and last.
So this is the turbo I bought for my 2.3 stroker evo Stao? I was hoping for a little more than that... :P
Stao,
have there been any updates for the CT12a turbos, one of mine pissed its pant suit on the way to work this morning.
Just looking at options at this stage...Is it possible for you to supply a manifold, gate and TD06 or similar turbo to suit a 1J?
Thanks
Zeb
For reversed turbine wheels there sin't that much of option yet available. Need to see what I can find.
KAMAK make a 9 blade SL2 wheel, I believe they call it their STS wheel. Why don't you guys try this? No machine work required, just assemble and balance.
Its meant to be a much lighter wheel, too. It has the potential for very snappy throttle response with the billet compressor.
We can high flow them and they will be good enough to support 300rwkws on a manual with supporting mods. Lot of work is involved in doing it how ever. So it might be working out cheaper with an high mount, but depending on what it is.
The cost to high flow both CT12As is $1800 and they needs braided oil and water lines after high flowing.
Alternatively, you can use our ATR43G3, SS2 or SS3 depending on what sort of power you are after. G3 is $900, while SS2/3 is $1150. 50mm HPVA gate that Ive been using on the R33 is $300 with the turbocharger. and Brae manifold is $1100.
There not reverse rotation only very few people sell reverse rotation turbines in the us
Kamak definitely make a 9 blade reverse TD06SL2, just need to ask.
Need to ask brae on this. Usually about weekish.
Cool
So, If I said I want a turbo with a big midrange, going on to make around the 300rwkw mark on 98 what would you suggest? the SS2?
Would be after something with a V-band dump pipe set up preferably.
The SS2 would be the most reliable turbo for this setup. The externally gated version usually comes with a Plate which a 3 inch metal pipe can be attached to as the font pipe. Or a Vband assembly extension that cost $100 additional.
details are at:
http://www.hypergearturbos.com/index.php?route=product/product&path=72&product_id=54
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
