Posting a little update. This is the SS2 based ATR28 turbocharger with a even larger turbine. This particular one runs off ceramic roller bearings. Hopping to get 300rwkws+ with 20psi by 4000RPMs.
That housing is nearly all turbine lol Surely that cant have a good nozzle area? You must have lost heaps when machining it to suit the turbine.
That's fine. You just need another one of my patented unspacers.
But seriously.....what size turbo is that manifold designed to hold up? For it to place it so close to the cam cover is a bit, um, wrong.
Edited by GTSBoy
Well I purchased it off someone on this forum stating it was for an RB25 and he planned to put a GT3582 on it. I bought it unused, maybe there is a reason it was unused....
I'm on my mobile at the moment so I can't search but surely it's not the turbo that's the problem? There would be pics of peoples high mount SS2 but I can't find them.
It would have to be the manifold I'm sure of it.
lol that is very wrong. The turbine is in a standard T3x patterned housing, means other T3s will have similar issues. I use Brae high mount and fits perfectly.
Definitely a problem with the manifold. I would say the jig used to make it would likely be overused and out of shape.
There is nothing unusual about the size of an SS2, its definitely not going to be much larger than a GT30/35 based turbo.
I have an ss2 low mounted on a 6boost manifold with no issues. Comp housing is a bit close to the engine mount bracket but no issues at all
That manifold is odd. If someone was going to run that sort of manifold with an ext wastegate an ss2 should not be an issue at all. Looks like youd need to have a stock turbo for that to work......
If its a 6boost then call or email kyle. Probably best to email him with some photos and give him your number. He might be able to give you an answer or organise an exchange of some sort
I think it make similar power as your GTX3071 hopefully with better response. If that works well I will enable VCT.
Taking consideration that my SS1PU made 30kw less than your test car (at the time on p98 w/cams) before it was maxed out, I am going to apply the same reduction to my GTX. In the end my car pulled the MPH to support happier numbers so I believe that's fair.
Just putting that out there before we compare the results from the 2. My car is a complete back to back, I have only changed the manifold and turbo. Considering I went to T3 high mount I should have more lag than you.
We will compare results soon enough. I'm sure they will either drive sales for yourself or give you something new to strive for
Most gtx3071r I've seen on sr20 are slightly laggier than the old gt3071r
Gt3071r 20psi by 4000rpm
Gtx3071r 20psi by 4500rpm
Both highmount t3 .63ar
But while the gt3071r will struggle to make 300rwkw on pump98 the gtx3071r will make that quite easily on 20psi and a lot more with more boost and e85 330-350rwkw
My results on my car with the ss1.5 were almost the same but I was on e85 his was one pump
For 20psi boost I made 250rwkw and he made the same but on pump 98
With 5 psi more down low and taper up top he got 270rwkw but he has a aftermarket manifold and step 2 cams mine is std manifold and poncams
E85 usually gives a 20kw gain on the same boost level
The difference would be the cams. I've compared mine with few that has Pon cams at Trents, The BC cams are making in average of 15kws more mid-top while the pon cams has 15kws more in mid-low with better response.
The GT3071 on my car hits 20psi by 4250rpms at 250rwkws, feels laggy down low.
Another update this is my latest ATR43SS2 turbocharger.Compare to the current one. Compressor inducer has been increased by 2mms, while the turbine inducer and exducer has been increased by 3mms. This particular one is expected to be maxed out at around 390rwkws on E85.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
